I started the truck and tested for the injector's ground pulse. I do get a dim light on the test light. Was the light supposed to flickering or stay on since the truck was running? I can use my voltmeter and see what the voltage is if that would help.
Does this mean the injector has a problem? Is there a way to test an injector on the vehicle? Would measuring the resistance of an injector mean anything useful?
Thanks
Check the working 1 and compare the light it should be  12v bright but the pulse may be so fast that it looks like a solid light. If it's not 12v check at the ECM
I can't really check the working one. If I disconnect it the truck won't run.
How do I check the ecm?
Can't you test it where you spliced in the new injector harnesses? No need to disconnect the injectors. To check at the ECM , using a wiring diagram determine which wire triggers the bad injector and test it at the ECM, you can take a needle and pierce the insulation on the wire if need be
It looks like the injector is bad. I measured the resistance and it is less than .5 ohms. The good one is 15 ohms.
I also found out that you can connect the injectors with either plug. Also, the individual injector connectors themselves are not polarity sensitive. So, I swapped the plugs and the passenger side would still not work. The driver side still worked. So, I can eliminate the ECM and wiring.
I order a TBI gasket set and a new injector. Should be here in a day or 2. I think I may just remove the complete TBI and work on it off the vehicle.
Thanks for all the help. I will let you know how it turns out.
This is what I would have suggested, but sounds like you are nearly there getting it sorted.
I hope so. I am surprised that the truck runs fairly decent with just 1 injector.
I was thinking about doing both. After I take the tbi apart I will clean and look things over. I am still undecided on redoing the fuel regulator. Normally I would just replace everything. Now I just want my truck back and running.
  • Haha 1
Too many variables, you'll never know what was actually wrong with it. What you spent money fixing that wasn't broken, you might fix the original problem and create a new one or worse, NOT fix the original problem, create a new and have multiple issues.
This is the WORST strategy for fixing a problem. Work carefully and methodically, test each part carefully prior to replacing, like with the injector. You found the culprit, repaired, then, importantly, confirm the repair solved the problem. Adding another new part to the mix doesn't confirm the original problem has been resolved.
Edited by asilverblazer
    AidenVorpagel
    AidenVorpagel
  • Who's Online   1 Member, 0 Anonymous, 1,213 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
