The original problem was the injector wiring harness. OBD1, I will clean the IAC.  I have had some issues with it over the years. Replaced the IAC and wiring 10 years ago.
I removed and cleaned the IAC. Disconnected the battery to reset. Same problem. I will drive it around tomorrow and see what happens. I didn't think there was too much carbon built up? The throttle top side plate is clean. When I was trying to figure out why it wouldn't fire, we sprayed quite a bit of throttle cleaner. Also, that is when we checked the injectors spray. All that seems fine.
See attached photo's
image.jpeg.43fa9aaebba277ec37955e477d0dcbc7.jpegimage.jpeg.f19fa5d97bbedb07f92d166a9cf4d5e9.jpeg
There is an idle relearn procedure, Google 94 Chevy pickup idle relearn procedure. It sounds like the IAC is working where you have a higher idle when cold. Also the TBI system had problems with vacuum leaks at the TB gasket and spacer plate so check that before trying the reset also check that the EGR valve is fully closed
Edited by richard wysong
On 5/12/2026 at 5:32 PM, dji1 said:
I did adjust the throttle cable
Did you or did you NOT adjust the throttle cables?
Was the throttle body removed during the repairs to the injectors?
Don't go looking for new problems in new places - stay where you are working and messing with stuff.
No, the throttle body was not removed. Just replaced the electrical connectors. Ten years ago, when I replaced the tpi base gasket. I did adjust the kickdown cable then.
I think someone told me on a 94 the kickdown cable was there but it did not control anything anymore. The sensors do all the tpi adjustments.
I did notice that the kickdown cable was tight and had no slack in it like usual. Not sure why or if it even makes a difference on my 94? I did loosen it a 1/4 turn this morning.
The kickdown cable controls the transmission, it has nothing to do with idle speed. Proper adjustment is critical to transmission operation. Consult the service manual for adjustment procedure
I reset the kickdown cable back 1/4 turn. While I was driving around today, I finally got an error code 44 (lean exhaust) The truck was warmed up, and I was idling at a stop sign.
I am going to re-check for vacuum leaks. I did replace the hose for the brake booster. I am going to check the wiring to the O2 sensor and remove and clean the EGR valve hopefully tonight.
I have been thinking about buying a fuel tester at Harbor Freight just to eliminate pressure issues. Any comments?
Thanks again.
Unless it is a tool you may use frequently the parts store tool loaner plan may be a better option. I don't know the price or quality of the H F tester. I have a Snap-On and the hose is getting stiff from the gas and lack of use. With the loaner if it has an issue it's not your problem
Yea that is the 2 reasons I haven't bought one before. I am sure I would use it once and have no need for it again. The only reason I thought about it was that it was only about $20 and I have never tested fuel pressure before and I am not sure if 1 person could, do it? I bought a brake bleeder kit years ago that I forgot I had. Found it in the garage the other day. Brand new never used it. When I was checking it out to use all the nipple attachments broke in my hand.
I may try the loner tool at the parts store. Never had in the past. I don't think the fuel pump is the problem this time. When I drive down the road the truck runs okay.
I re-checked for vacuum leaks again last night and I don't hear any. I also checked the wiring to the o2. It looks excellent. I am going to re-check the injector patten in a few minutes to make sure. I didn't remove and clean the EGR valve last night. I replaced the gasket and cleaned it less than 10 years ago that is only less than 50k mile for me. I still may do it.
Should I start a new thread for the idling problem? It is no longer a won't start issue.
Thanks
It looks like the passenger side injector is not flowing much at idle. I think. It is hard for me to see for sure. I may just pull a plug on that side to see what it looks like.
When I give it gas, I can see the flow on both ejectors. The driver side looks okay.
Can I swap the connectors from 1 injector to the other side injector? There is a very small chance that when we soldered the new connectors on something went wrong.
I took a video with the truck running.
A timing light hooked to the coil wire or any fast strobe light shining on the injector spray will help you see the spray clearly. An injector not spraying at idle will indeed cause  erratic idle rpm. The way the tool loaner program works is you pay for whatever tool you want to borrow and they refund your $ when you return it. Great for tools you may only use occasionally. You should be able to switch the wires between injectors as long as the polarity is the same. 1 wire is 12v+ with the key on, the other is a pulsed ground from the ECM to fire the injector. If it sprays under open throttle the injector is at least partially operational. I'm not sure if the injectors are polarity sensitive so you might want to consult a wiring diagram. (Charmli,free service manual download with wiring diagrams)
I am going to try the timing light suggestion. I purchased my timing light in the early 70's. It has a spring that you attach one end to the plug and the other end to the wire. It's not user for sure but it works so I have never upgraded. I also will try and set-up more lights so I can get a good look. The shadows under the carport were not good this afternoon. I can also move the truck to a better position if I need to.
I will check the polarity of the connectors before I swap them.
Thanks
Another obsolete tool, the timing light, I have a top of the line Snap-On that hasn't been used in at least 5 years. I think I have more obsolete tools than useful 1s
The passenger side injector is not working at all. It is getting 12 volts. I couldn't test to see if the ECM is sending a signal to the injector. No one around to help crank the truck today.
I was going to buy a Noid light at AutoZone $5.99 but they don't stock it. They just advertise it online. I'm going to modify my test light and see if that will work.
Didn't have a problem today seeing the injector (no) flow. The natural light was perfect.
If the ecm is the problem, would it affect both injectors?
Or if 1 injector is working then the other injector has a problem.
I'm pretty sure the ECM has separate drivers for each injector so a bad ECM is a remote possibility. You should be able to test the ground pulse with a test light with the engine idling, just hook the clamp to the positive post. If no pulse check it at the ECM before condemning it
    • Here's the second UOA on my 22 Wrangler with the Ecodiesel. This has 5k miles on AMSOIL Signature Series DEO 5w-40. The first one was dealer installed oil, no clue what it was, the second is what AMSOIL recommended, European FS 5w-40, Most of the Ecodiesel world is showing great results using the European MS 5w-40, I figured I would see how the DEO works. This is using an Ecoguard oil filter. It's my understanding this engine likes to shed aluminum.  We will see. So far I don't think this is too bad.
    • I'm surprised nobody seems to offer a solution like the start/stop device I put in my new truck. Remembers my setting when shutdown. And while it still starts up in start/stop, it stores/evaluates what mode it was in when shut down and will change it whithin a second or 2 of startup. It'd be nice to have something like that for the DRLs.
    • 2015 Sierra 1500 here. Leaks from the sunroof to front driver side and soaks carpet. How do I fix this? Thanks!
    • I will be doing that for sure, but I need to solve who has/ where I can find a bidirectional scan tool that will support OBD 1.5. I'm kicking myself because I ebay'ed a Snap On MT2500 that I didn't think I'd ever need anymore. D'oh!! I'd rather not buy another, so I'll contact a few local shops to see if they have one and how much they'd want to do the procedure. I'd rather have the ability to do it myself... I wish there was a modern tool that could do it all, but I'd have no idea what to buy.   The theory with the pulled timing is that it mimics a rich condition. The delayed spark causes incomplete burn and the O2 sensor picks up low oxygen levels. That's interpreted as a rich condition so the PCM pulls fuel and that shows up in the deeply negative fuel trims.
    • An ultra wealthy man had the most beautiful daughter. But, there was a problem. Everything she touched would melt in her hands. No matter what, Metal, Wood, Stone. Anything she touched would melt. She could not feed herself. Because of this, men were afraid of her. Nobody would dare marry her. Her father was despaired. What could he do to help his daughter? He consulted doctors, scientists and anybody who could solve this problem. Finally one of them said, "If your daughter touches one thing that does not melt in her hands, she will be cured." He was overjoyed and came up with a plan. The next day, he held a competition. Any man who could bring his daughter an object that would not melt in her hands would be given billions of dollars to marry her. Three extremely intelligent and handsome young men took up the challenge. The first brought a very heavy steel rod, But alas, when the she touched it, it completely melted in a matter of seconds. He sadly went away. The second brought a beautiful diamond, knowing diamonds were one of the hardest substance in the world and would not melt. But alas, once she held it in her hand, it melted. He too was sent away disappointed. So now, there was one left He was very nervous & sweating. He approached the daughter & said, “put your hand in my pants pocket and feel what is in there." She did exactly what he asked. She felt something very hard. She held it in her hand, squeezing it as hard as she could. It did not melt & remained extremely hard. Her father was overjoyed. Everybody was overjoyed. She was finally cured. Nothing never, ever melted in her hand again. They married and they both lived happily ever after, raising a wonderful family. Question: What was in the the groom’s pants pocket??? Answer below ↓ M&Ms of course! They melt in your mouth, not in your hand. What on earth were you thinking?
