I started the truck and tested for the injector's ground pulse. I do get a dim light on the test light. Was the light supposed to flickering or stay on since the truck was running? I can use my voltmeter and see what the voltage is if that would help.
Does this mean the injector has a problem? Is there a way to test an injector on the vehicle? Would measuring the resistance of an injector mean anything useful?
Thanks
Check the working 1 and compare the light it should be  12v bright but the pulse may be so fast that it looks like a solid light. If it's not 12v check at the ECM
I can't really check the working one. If I disconnect it the truck won't run.
How do I check the ecm?
Can't you test it where you spliced in the new injector harnesses? No need to disconnect the injectors. To check at the ECM , using a wiring diagram determine which wire triggers the bad injector and test it at the ECM, you can take a needle and pierce the insulation on the wire if need be
It looks like the injector is bad. I measured the resistance and it is less than .5 ohms. The good one is 15 ohms.
I also found out that you can connect the injectors with either plug. Also, the individual injector connectors themselves are not polarity sensitive. So, I swapped the plugs and the passenger side would still not work. The driver side still worked. So, I can eliminate the ECM and wiring.
I order a TBI gasket set and a new injector. Should be here in a day or 2. I think I may just remove the complete TBI and work on it off the vehicle.
Thanks for all the help. I will let you know how it turns out.
This is what I would have suggested, but sounds like you are nearly there getting it sorted.
I hope so. I am surprised that the truck runs fairly decent with just 1 injector.
I was thinking about doing both. After I take the tbi apart I will clean and look things over. I am still undecided on redoing the fuel regulator. Normally I would just replace everything. Now I just want my truck back and running.
  • Haha 1
Too many variables, you'll never know what was actually wrong with it. What you spent money fixing that wasn't broken, you might fix the original problem and create a new one or worse, NOT fix the original problem, create a new and have multiple issues.
This is the WORST strategy for fixing a problem. Work carefully and methodically, test each part carefully prior to replacing, like with the injector. You found the culprit, repaired, then, importantly, confirm the repair solved the problem. Adding another new part to the mix doesn't confirm the original problem has been resolved.
Edited by asilverblazer
    • I find it amusing the OP doesn’t realize this threads heading includes several engines. He should have posted in the off topic section if he wanted a more narrow focus. I really appreciate and find amusing that he actually pointed out one of my many vehicles. The Odyssey. That happens to use 0-20 oil. I love pushing his buttons.
    • Maybe, but it seems he is the only one that has backed up data to prove what he is stating. I think he is doing this more because he enjoys it and wants to get the information out to us. He's got the knowledge and access to the proper equipment and having the funds doesn't hurt.  I would love to do what he is doing and would do it if and when I hit the Powerball.  I'm not a Tribologist by any means but love to learn what I can.   I would bet there would be doubting people out there if a completely independent lab with high quality work and highly respected in the automotive industry, put out information like this.  The world can't be pleased, one just has to take the information that they are given, do more of their own research to find actual lab data to back up what they are trying to figure/find out.  Most don't bother, they just want to believe what they first see.     I don't have the minimax but my 6.2 in my 2019 Silverado with 64k miles shows excellent UOA results with 0w-20 and for my own purposes 5w-20.  Since not much of a change using 5w. I liked the data sheet information on the SS 5w-20 and figured I would give it a try.  Still the same viscosity at 100℃.   In the end we all just do what makes us happy, life is too short to get upset over trivial social media.   On a side note, I do feel GM has dropped the ball and just cares about the bottom dollar and not quality anymore.  "Like a Rock" has been long gone.  Seems "Built Ford Tough" has as well.
    • Better than stock but that's like putting lipstick on a pig
    • Hello, my 3 month old Sierra Elevation wont recognize a trailer with electric brakes? All the lights work correctly, but no power to the brakes?   This is the factory installed brake controller. If you manually push the knob, the display shows the power % but does not light up like my 2022 silverado.   I have an appointment with the dealer, but was checking to see if anyone else has seen this issue.    Thanks,
    • Been using SS 0w-20 from new, but wanted to change to the 5w-20 because I liked the data on the data sheet, to me it seems like a little better product. But as you can see, not much difference. This is also with running a mix of 10 gallons E85 to a tank topped with 93. It isn't a flex fuel vehicle so any higher I get a CEL for running lean on both banks. Yes my mileage takes a hit. Instead of 20 mpg I normally get on trips I get 17mpg. This is also using EaO17 filter.  What is amazing is I have the AMSOIL cone filter on it since I have the GM Performance intake installed and that air filter has 44k miles on it.  I just take it out and shop vac it off once a year.  I use the upholstery tool on my shop vac.  Works well.
