I have a 2022 Sierra elevation which i bought last year February. The dash lights up with different Warnings:
Service traction control, Service transmission, Washer fluid low Add Fluid, Service 4WD,Service ESC, ABS, Fuel gauge fluctuates from empty to full and then it say "reduce acceleration Drive with Care" and I can't go over 64 miles an hour. I have replaced the BCM, checked battery, checked grounds also had transmission checked. I dealt with the dealership for a year and no help so my independent shop is hunting down the problem. It happens randomly. It can happen for a few days in a row or every 2000 miles. I have noticed a hard gear shift right before it does it. Any help would be appreciated. I love the truck but it is unreliable. Here is a list of the codes:
U1611, U1610, U0142, U0418 ,U0131 ,U0073 ,U0447, U0146, U0140, U0073 ,U0102, U0403, U0102, U0151, B1981, U0401 ,U0423, U0566, C2A07, U0100, U0121, P0700, P1789, P00FF
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
