In my ignorant haste while replacing my front door speakers I forgot to attatch the wire latch to the inside door handle on the door panel that disengages the lock to open the door. Now that the door panel is back on and door shut, there is no way to open it to remove the door panel to fix this. Will not open from outside either. Anybody have an idea of what I can do to open it. Is there a way thru the inside door handle area?
Edited by Digitalkha
  • Digitalkha changed the title to Need help with opening front door on a 2024 Silverado cable was not attached when reattaching panel
If you can roll the window down you may be able to look down at the latch and use something to pop the latch. Or you may be able to see the loose end of the cable and pull on it to pop the latch. Not sure about the 24 Silverado but this worked on a 2012 Silverado (bent a hanger to pull on the latch release).
***BEWARE OF AIR BAGS***
Jay
Edited by Jay P
You probably have this figured out by now, but just in case. I MAY or may not have done the same thing once.... I was able to open mine from the outside. I wonder if the rubber around the door lock plunger thing on the top of the door card (no idea what it's called) is impeding that from coming up? I'd think you'd be able to get in from the other side and pop the rubber around the door lock out and the open from the outside, maybe?
Edited by taze
As an update to the situation if anybody happens to run across this problem... even though I called about six dealers all telling me from taking the fender off and unhinge the door to cutting the panel off, which I was ready to do. But all I did was bend the top half of the door panel back at the top by the window. I assumed the door panels with all the plastic were quite rigid but apparently on the new Silverados they are quite soft. I got the idea from a guy replacing a window sweep on a 24 Silverado and all he did was work the top of the door panel where it's inserted by a lip where it meets  the window and bend it back ... had access to the whole inside.
  • Thanks 2
    Tbhats2130
    Tbhats2130
  • Who's Online   3 Members, 0 Anonymous, 2,437 Guests (See full list)
