I took my truck in for a left side bumper/tailgate/fender repair estimate.
There is a section of the tailgate jamb that I was hoping someone could verify and send me a pic of theirs.
I have attached two pics...left and right sides of tailgate jamb.  Red markings indicate areas I am referring to on damaged side.  Green marking indicate left side where no damage occured.
The sheet metal edge that is spot welded and two black screws on each side is where I am focusing.  The left side sheet metal vertical section along the edge has almost no gap and the lower black screw looks more forward (compared to right side).
Can someone who has a 2023 2500/3500 snap a couple of pics of this same door jamb section on both the left and right side and post and/or send to me.  It would be much appreciated.
Thanks!
Year won't make a difference.  Its all the same sheetmetal on HD 2020-2026.
Here's a brand new truck showing the left and right sides of that spot weld area.
Thanks newdude, much appreciated!
It looks just like my truck after the damage, meaning that area was not compromised.  Apparently on the new trucks the left side does come from the factory with  lower black screw off center/forward ....relative to the sheet metal hole cut out for it, and less gap on left side (compared to right side) in the area where sheet metal comes together for spot welding.
That screw is just holding the tail light in. There should be some play in where the screw can be tightened to align the taillight.
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
    • It has happened to me a few times. I carry a jumpstart-tire inflator with me.
