So I’m looking to swap my 2022 halogen to 2024 led 2500 hd front. I have the grill the headlights - halogen to led 8 to 12 pin wiring harness. I just found the front bumper upper cover facia and I’m looking to see if anyone has a parts list to help me out with. I’m going to need the mounting brackets to install the grill and headlights. I’ve been on some gm parts sites and it’s just horrible trying to figure it out.
There's no additional mounting brackets for the grille or headlights. The only difference between the grill mounting is the active grill shutter frame to which the grille attaches too. There is a slight difference between the older and newer shutter frame, but you CAN reuse your existing one. There'll just be a couple clips that won't attach to anything. The headlights fasten exactly the same. The only brackets you'll need are a couple for the bumper.
Edited by carkhz316
Ya know...you just need a VIN from a truck that has what you are trying to do...
cars.com, autotrader, etc.  Find an LT Trail Boss or LTZ, copy the VIN and finding the parts will be much easier.
2024 Silverado 2500 HD LTZ grille no camera Parts list
84603331
84913656
84913657
84913654
84913655
84911567
84911568
85646092
85646093
85797921
85797922
11570637  x10-15   grille/bumper bolts
11546500  x10      grille clips
11571006  x10      push/retainer clips
11546454  x6       nut retainers
11611609  x6       M5 bolts
11610700  x6       molding/trim retainers
