Hello from Australia :)
Just sharing that there is now a way to delete the active shutters entirely with just a plug in module.
Opens up tons of room to light bars etc.
Hello @jaszr2 Do you have a link for the item? I put a replacement bumper on my truck and consequently had to relocate the shutters. I studied on them a while, and figured if you left a couple key blades, you could get most of the airflow with probably no throwing codes.
Yeah Orginally over here that is what we were doing to, but it kept being an issue when we would put 2 or more light bars in, 100% worse on the new 2500 it has even less room.
I still have to enable shipping for usa, just waiting for bean counters to tell me what the go is with your import duties now.
lokiauto.com.au/shop
5 minutes ago, davester said:
you need to become a vendor before you can offer your product for sale on this forum (like pretty much every forum)...
I did look for that when redoing this account but found no option for it. If you know how please point me in the right direction.
