5 hours ago, jgaudet99 said:
60psi front and 80psi rear
But I am not running the factory tire brand or size!
it's load range F Toyo tires
Here is an image of a quick Google search about these tires on my truck and it's exactly same psi recommendation the Toyo tires company gave me!
I'm not looking for anyone else recommended psi or anything, I'm just looking to see if anyone knew a way to get rid of the factory low psi warning light, because I'm not running high psi and ruining my tires when I'm not towing!
You SHOULD be.  IF you underinflate, you can compromise the truck's handling and stopping.  Its an 8400lbs truck.  LOTS of weight on the front end empty.
Ideally you'll want 55-60psi all the way around.
Tire light.  GM dealers won't help.  LIABILITIES.  Others have mentioned tools that exist.  That will be your only route.
In the motorhome world, people refer to tire manufacturer's pressure-weight charts to determine a good PSI for their motorhome tires.
What they do is get axle weights for the vehicle at a CAT scale or other scale. Drive on, drive off, the scale spits out a ticket with the weight over each axle. Then, you know the approximate weight per tire on that axle. Then, you refer to the pressure/weight chart published by the manufacturer and set the tire PSI accordingly.
Of course, you will want to adjust (and know how much to adjust) when you decide to carry more weight. For everyday unloaded ride, bringing down the PSI within a safe range that still adequately supports the vehicle's weight relative to the construction of the tire can really help with ride quality and under/over-inflated wear issues.
I don't see why it would be any different for a pickup. The key is the tire needs to be rated to support the load safely at the PSI you've selected.
Edited by Atlas
  • Thanks 1
    juggernautusa
    juggernautusa
  • Who's Online   4 Members, 0 Anonymous, 1,188 Guests (See full list)
