MAP Sensor
Can the MAP sensor be cleaned? I'm planning to clean the TB and since I'm there..
Also, If the TB is removed can I get better results with cleaning it? And I remember reading about spraying the intake behind it with something to clean it out? Also, EGR removed and wiped cleaned and tested, is there a gasket or sealant I should have available to replace it?
:cheers:
