New (for me) truck...
This is the aftermath of dericing my truck...
The previous owner had put on some Pep Boys fake carbon fiber "racing" pedals. As you can see, the clutch and brake no longer have their rubber pads, so I will need to get some from Ford (roughly $800 at the dealer probably :) ).
If anyone wants some slightly worn Pep Boys carbon fiber racing pedals, they are all yours! :cheers:
Hmm....Maybe you should have got the new pads before pulling the old ones out. :)
I can drive with the bare metal, it doesn't bother me that much, but I will get new pads when I get around to it. I hated those stupid Pep Boys things and the brake pedal one was falling off anyway.
PSST, hey paco! the pedals themselves look riced out too, better take em out!  :)
Now the fun begins :cheers:
Stop whoring my d**n thread. :cheers:
BTW - Wingnut, don't you like my vinyl seats and dirty rubber floor mat? I have an AM/FM radio too!!! :cheers:
To each his own man, I never said that I had anything against them. I just said that I wouldn't have them. I'm just happy that your cynical butt found a truck that you wanted, and cant really biatch about because you picked it. :cheers:
But you do need a head check if you think driving with those slick-a$$ metal pedals is safe. You should go to the parts store and pick up some rubber covers ASAP. You get just a little mud or water on your feet, they will be slipping off constantly.
Again...Congrats on the new ride :)
Yeah, the Ford dealer will have them tomorrow and that's when I will put them on. The carbon fiber pedals were worse. They were very slick (also metal) and the brake pedal one was falling off.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
