Power Loss with A/C On
How much power loss is typical with the A/C on?
I've got the 6.0L and the power loss is very noticeable. I know I should expect some but I'm just wondering how much is too much?
Join the club..I know I only have a '95 w/a 5.7L but it gets down right DOGGY off of the line when the A/C is on...I think between the compressor and the alternater,it ROBS almost 20 horses,at least thats what it feels like :rolleyes:
:rolleyes:
Same here..... gotta really wind her up to get her goin with the A/C on
One good thing about the A/C is its meat locker cold though!!!
Hmm....granted I have a 94' 4.3L, I don't really notice any power loss. My mileage is a little different, but not much. My AC usually effects mileage by about .5-.9 mpg. Maybe my truck is just extra efficient??
you have a 6.0L and can tell a differance in power when the ac is on?!
i would say something is wrong, my 6.0L doesn't change a bit power wise when ac is on. it will use slightly more gas when ac is on... maybe .5 mpg. my truck pulls right at the gcvwr with ac on... still has plenty of power.
the only cars i've "noticed" when the ac was on is usually 4cyl cars that are already under powered to beging with.
I've got a 5.7 in my 2000 pickup and I can hear (sometimes) when the compressor comes on but haven't noticed any power difference. Very unlike the 97 Plymouth Grand Voyager with 3.0 that loses considerable acceleration with the AC on.
I have to say that I have not noticed any power loss with my '04 with a 5.3.
I hear the compressor turn on and I can vouch like the others that the gas mileage takes a small hit.
Now, I haven't towed a load with the air yet, so maybe that makes a difference...
With my '02 Z71 5.3 w/ 3.73s, I don't even notice a difference with the A/C on. Towing or not... However, My '91 Suburban with a 350 was a dog with the A/C on...
James.
Neither of mine have hardly any power loss with the AC.
I won't lie and say that there isn't one, it just isn't all that noticeable.
5.3 in the 02.
5.7 in 92.
In my 04 5.3L Sub it is barely noticable that the AC is running. An easy way to exaggerate the lag is to turn on the compressor as you are accelerating up a highway ramp. While I haven't towed with this vehicle, I would turn off the AC anyway on hills and the like. On hot, hard tows, I actually used to run my heater (as an auxilliary radiator) with the windows down while towing two Sea-Doos behind my 2.2L Subaru Legacy just to be sure! :seeya:
Come on down to AZ in the summer when it's a good 110+. I have the A/C on plus every time I stop the cooling fan clutch kicks in. Feels downright gutless. Sounds cool though sucking all of that air through the radiator. :rolleyes:
Well....technically, no power is lost. If you try to measure max power on a dyno or your nearest on ramp, you'd be at wide open throttle right? As far as I know, modern vehicles have a logic in their PCMs to disengage the A/C clutch at WOT to make sure the A/C doesn't steal any power.
Just cruising along though, the drain varies based on A/C system pressure/oil levels, compressor efficiency, and ambient temp. I wouldn't be surprised if it's as high as 20hp on some vehicles. I remember a funny bit of creative writing in one of the car mags a while back referring to driving a puny little 4 banger econobox. "Turning off the A/C was like turning on a supercharger."
Rob
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
