SERVICE 4WD IDIOT LITE
While driving this pm in 2 wheel drive, 49k miles, out of no where the SERVICE 4WD IDIOT message was displayed on the instrument panel. This must mean something but what? Either a problem is about to occur or has occurred. Is it something that needs immediate attention by the dealer? I did park the truck and after supper I started it up again, now the IDIOT message is not displaying. Any thoughts or suggestions ?
Thanks for the responses
Does it have the Push Button AutoTrac 4x4 switch?
If so, its most likely that. I had mine go south right in the middle of a winter trip up through the Adirondacks (through snow)....
Turns out it was just the switch for me, and it is most of the time.
If you are POSITIVE its only the switch (which it sounds like if the light goes out after you restart the truck), then I would check out
www.gmpartsdirect.com
and get the replacement part, instead of paying the Stealership around 80 bucks for like a 30 dollar part. The entire bezel pops right off, and is only a few screws and a connector.
Good luck
there is a servie bulliten out on this. I took mine into the dealer, told them about it and they knew exactly what I was talking about. i was around 14000 miles when it happened to me. The reset the computer as far as I remember. If you are in warranty it is a fast cheap fix.
