Vibrating Gas needle
My gas gauge has started vibrating between tic marks. Looks blurry. I believe the average position of the needle is accurate although it also hunts up and down the gauge a little bit. This started happening after my battery died. When I replaced the battery the problem now existed. The fuel pump/sending unit is only 6 months or so old. The alternator has been checked out and is ok. Any idea whats going on here. I have seen several other individuals with the exact same problem but no one nows the solution. Tahoes seem suseptible to this as well. Thanks. My suspicion is that something didnt like the low voltage. gauge? computer? sending unit?
Dan
You'll need to find out if the voltage fluctuation is being sent to the gauge, or if the gauge is doing the fluctuation with steady voltage to it. Unfortunately you probably will only be able to do this with a scan tool.
Does it do it in Drive? If so, I think you'll find it is a bad gauge (instrument panel) because the signal is buffered out of park and neutral.
The dealership also may have updated software, but I'm not aware of any for gauge vibration.
Hope this helps.
I have the SAME problem. I can't find ANY info on it. it started doing this 3 days after I bought the Tahoe... with 78K miles. Its annoying, but its acurate. I bought an OBDII scanner from Wal Mart and I had some code that had to do with emissions. I wonder if you have that same code? Is your SES light on???
The SES light was coming on about a month ago with an emission code 042 or 442. Cant remember now however it was an emmision code and the fix was a new gas cap. The old one seemed fine but I guess the o-ring had shrunk over the years and no longer sealed tight enough. put on a new gas cap (autozone) and light went out before the next tank fillup or shortly thereafter. It takes it a little while to decide the problem is fixed.
On the gauge thing mine I think was caused by the battery going dead and me trying to get it started with jumper cables i guess. Anywho mine seems to be accurate as well or at least consistant in its movement downward. Im not to the bottom of the tank yet so Im not positive its accurate. It tends to wander/jump around more when it is in park. Also it tends to peg out sometimes right as I turn the key to start the truck.
Well, looks like we have the same EXACT problem. My guage goes all the way past "F" when you turn on thekey then is jumps back to where it should be. And mine jiggles more in park than Drive. The code I'm pulling is P0452 "Evaporative Emission control system pressure sensor Low Input". I've tried 3 different gas caps two STOCK and one LOCKING. I still get the code after erasing it. Perhaps that isn't MY problem. As for the fuel guage, I've never jumped off my Tahoe. And it started this the FIRST time I filled it to the brim. When I bought it it was empty... thats alot Ross Motors for giving me an EMPTY car! :thumbs: Well, maybe one day someone will figure it out.
I had same problem on 98 Sub. It was th guage itself. If youve looked at a cluster
w/ gauge faces off the all the gauges are driven by coils. These apparently go bad and cause errratic readings and blurriness. They are not available individually as far as I know, but can easily be replaced if you have donor cluster
    • Actually, it probably was the brakes.  It's weird the way the messages came across, but I took it to the dealer thinking that something was wrong with the sensor and in fact, the rear brakes were shot.  What I don't understand is why the messages never said, your brake pads are low.  First I got the message I posted above, taking about new pads being detected.  Then I got a message saying that the system needed repaired.  It never said, change your brake pads.
    • Did the KYBs keep it the same height in the front? I was concerned that pre-assembled assembly would raise it up an inch to standard non-z60 height.. I guess which it would make the rake 1 inch instead of 2 inches.
    • Thank you for keeping the train on the tracks and for a thoughtful engagement. I enjoyed the reflection on a previous stance to refine and improve your position. I like that inquisitive flexibility about you Atlas.    No the process isn't sterile. Hundreds, perhaps thousands of miles of piping, vessels, pumps. Chevron, the people I worked for, were keenly aware that there is a market for what is known as their "ISOCLEAN" line of lubricants. These are lubricants that are the same as those sold bulk that are further processed by filtration to a level your particular application demands. They will filter and package and provide lab documentation as required. Do not kid yourself. Every gallon of oil that goes into a Chevron Turbine, reciprocating compressor, generator is prefiltered and tested before being charged. Lest wise it was when I was there in the plants I worked in.    There are requirements set by manufactures for the cleanliness of the oils used in their equipment. OTR such as CUMMINS has standards shared with customers on this. Commercial interest selling to Ma and Pa do, but don't share that information. Not even upon request but internally, they do exist.    The GM study sited, (Graph from Machinery Lubrication in previous post) only shows "relative" importance.  I find that fascinating. By constructing the graph like this they admit there are dozens of factors in engine life and via scientific method determined the effect of 'relative cleanliness' on engine life not in miles but in 'FACTORS'. This allows a certain amount of reverse engineering does it not?   They even provided some touchstones. Beta 75 as a reference point. Wonderful stuff!!   Smaller blenders CAN and some DO take the time and effort to do better than a refinery or large bulk blender, like Warren Oil, in improving the "in the can" cleanliness. No I don't have a list but testing could generate that information.    Again, but one of several levers we can pull to improve engine life. The simplest is keeping a clean work station while doing your own oil changes.
    • Thank you. I'll give it a try
