Cant get my SWR's down?
:seeya: This is becoming a nightmare.
I hope someone can steer me in the right direction. 04 sierra 2500hd shortbed ext cab.
I'm testing the SWR in an open area. Radio is a uniden 68xl tweaked. I'm using 18' of rg58? coax, firestik II 4ft antenna mounted directly in the center of the front bed rail just behind the cab on a small spring.
I have tried a new mount, new cable, new antenna, grounding the mount directly to the frame with 0 gauge wire, running a ground straight to the battery, to the cb, and to the mount, then to the 0 gauge ground....
SWR's are still 2.5, and 3+ on 40.
The radio has a tuneable tip, I have it screwed all the way in and 40 is still higher than 1.
What is the deal...can someone P-l-e-a-s-e shoot me some help before I destroy this radio with a bfh...
Is there any change on the meter, even slight when adjusting the antenna?
Are there changes adjusting at channel 1 then 18-23 then at 40?
Turn the antenna in it's mount at 45 degree intervals, any changes?
Not that it would be a permanent position, bumper? can it be adjusted?
Do you have aftermarket window tinting that possibly contain too much metal particles (heat rejection)?
Radio correctly grounded, maybe add "radio frame" ground
