front end leveling
Follow the torsion bars back from the lower control arms to the crossmember..at the crossmember the end of the bar goes into a "key" (cam) on the end of that there is a bolt...mark the head of the bolts so you can keep track of the number of times you turn them...you should turn each bolt the same amount..I suggest that you roll the truck back and forth about 4-5 feet after each adjustment you make, so that the suspension "settles"....I would not raise the front end more than 1.5"
so not to throw the geometry off.....THIS WILL AFFECT THE WAY YOUR TRUCK RIDES....you should also have the headlights re-adjusted and consider a front end alignment as all will be affected also......
Should have specified that this is a 2wd, don't think torsion bars apply. I was :D talking about a leveling kit that included " spacers" on top of the springs.
Should have specified that this is a 2wd, don't think torsion bars apply. I was :bs:  talking about a leveling kit that included " spacers" on top of the springs.
DOH! I shoulda asked :lol:
