Foglight bulbs for Denali
One of my fog lights went out on my Denali. How easy are the bulbs to change and what bulb do i need to get to replace it with. I would prefer to go OEM, but would not be opposed to going aftermarket if the results warrant it. Thanks for your help.
I know on my Escalade ( I think both trucks have the same fog lights) it is very easy to change the fog light bulbs, just lay under the fog lights and a 1/4 twist and the bulb is out (you remove it from the rear of the fog light), release the tab on the wire and that's it. Sylvania Silver Star is a good replacement if you want a whiter light.
Bulbs are easy to change. Daylights or "running lights" go out all the time. So I'm used to changing lights. You're going to have to get under there and look at it a bit to become familiar with the plug of the light.
First of all make sure everything is plugged in right. Those plugs usually have pretty tight snaps (or whatever that plastic device is called), but make sure a piece of plastic didn't just break off or something.
If everything looks right and it still isn't coming on then take the old bulb out (you could probably figure it out after fooling around with it some, even I did!) and take it down to your local auto parts store to match it with a new one. If they come in packs of two, even better!
SYLVANIA Lamp Replacement Guide
GMC 2001 Yukon Denali
Scroll down to view all replacement bulbs for this vehicle,
or select a specific application from this list:
Please SelectLow beam headlamp High beam headlamp Parking light Front turn signal Rear turn signal Tail light Stop light High mount stop light Fog/Driving light License plate Back up light Front sidemarker Glove box Map light Dome light Step/Courtesy light Under hood light Daytime running lights
When more than one part number is listed for the same application, please refer to your owners manual to determine which lamp is right for your vehicle.
Low beam headlamp
Part number = 9005
Upgrade Part Number = 9005ST
Silverstar High Performance Halogen Upgrade: The Look of HID: Whitest, Brightest
Upgrade Part Number = 9005CB
Cool Blue Halogen Upgrade: White Hot; Super Cool; 100% Street Legal
High beam headlamp
Part number = 9005
Parking light
Part number = 3157NALL
Upgrade Part Number = 3157AST
Silverstar Signal Lighting: Complete the Look: Crisp, Clean, Style
Front turn signal
Rear turn signal
Part number = 3157LL
Tail light
Stop light
Part number = 194
Upgrade Part Number = 194LL
Long Life Upgrade: Up to twice the life of the standard lamp
Fog/Driving light
Part number = 880
Upgrade Part Number = 880ST
Silverstar High Performance Fog Light Upgrade: Whitest, Brightest, 100% Street Legal
License plate
Part number = 194
Back up light
Front sidemarker
Part number = 194
Glove box
Part number = 194
Map light
Part number = 161
Dome light
Part number = 211-2
Step/Courtesy light
Part number = 168
Part number = 561
Part number = 74
Under hood light
Part number = 93
Part number = 4157LL
    • Diesel or gas?  The 37s will obviously, drastically reduce mpg, but the gasser will take a bigger hit to mpg, and power.    I wouldn't sweat a gear change on a duramax at all, and unlikely on the gasser either. You're obviously not concerned with acceleration or towing, and the 10spd will find itself in the right gear without much hunting, if any.
    • I understand. It is disturbing to think a manufacture asks so much and gives so little in engineering support. This is not a GM issues, this is a greed issue and one the ALL practice.    My intent was not to remove the wind from anyone's sail but rather to point out the areas deficient so that they can be discussed with improvements the goal. But to do that you have to know the truth and what that truth is.    The commercial interest are honed in on a few select issues in which they control all the variables and are not forthcoming in the least with their customers about the details. Failure is the only thing that drives these people to improvement. One way not to fail it to manage public "expectations". The set a bar they can clear and put their thumbs under the suspenders with chest puffed.... Only the internal data tells the story fully. As we don't have access to that for decades then we have to generate it ourselves. UOA's with data that matters.
    • I had skimmed through that article when you posted the link and honestly I felt rather defeated in a sense and realized that all these years in changing oil that in fact putting in what I was told was a good quality oil was probably not filtered as well as it should be although the filter put on the engine would be what ( as long as it never went into bypass mode ) would be the final filtering of the new oil that the engine components would first see, but then the filtering media itself is not up to par to what is ideal because a full flow filter would be too restrictive to filter fine enough for the engines best outcome in the long run. Only one of our tractors over the years which was a Versatile with a 855 Cummins had a separate bypass filter, some engine manufacturers did spec a partial bypass system within the main oil filter but I don't believe any other trucks or equipment I was servicing used such a filter. No doubt a product like the Amsoil bypass system is of benefit as long as nothing goes sideways with the extra plumbing and filter such as a rupture/leak that could cause the oil to pump out of the engine ( yes that Versatile had a remote canister with hoses routed to it as well ). With the idiot egr system on a diesel and as a result forcing a lot more soot into the oil, that certainly isn't helping the diesel engines cause or as you pointed out the GDI engine issue with creating more soot and aside from having a fancy secondary filtering system, changing the oil more often helping lower the total soot load.     So oil manufacturing and the end product is not something one can control and I wonder if there are specs on what various oil packaging companies produce in particle count or size. As to the filtering, if the OEM is not designing a filter size and spec that is really what it could be, they too are short changing the end user and so what is the answer. Of course as you say the oil side can only do so much if the air side isn't keeping up its end of the picture and air filters are only so efficient and if in a dusty environment such as farm or construction or driving gravel roads there is a lot of dirt to filter out and some of that ends up into the air stream.    Of course the irony in places like where I am where they dump the salt on the highways but also will mix in some calcium or outright pure calcium for problem road area's, or using calcium as dust control on gravel roads, the vehicle that gets used in that environment may rust out before a properly engineered engine and maintenance finally wears out so one has to face that reality in the rust belt.
    • Has anyone run these on their 2500?
    • have you stuck with dealer oil changes since then? I made the same switch after getting tired of crawling around under the truck, but I’ve found some dealers are way better than others about getting you in quickly. Curious if yours has been good about scheduling or if you’ve had to look elsewhere for quicker turnaround.
