new member here, just brought my 2003 1500 two days ago, first time owning an GMC. retired my old 1989 f150 :) . I love the 1500 so far, has the v6 in it. i do get an gas type knock or ping noise when starting it after it's warmed up ( not while driving, only on start up), maybe it's the cheap gas i put in it....any idea's?
A ping noise when starting up after a hot soak...that's a new one to me. Usually these things give you the infamous piston slap when cold, which usually goes away after a minute or two.
I wonder if you're hearing the purge valve duty cycling...makes more of a tick than a ping though. Maybe expansion of exhaust/heat shields. Could be a gremlin under the hood...those dudes are tricky. :lol:
new member here, just brought my 2003 1500 two days ago, first time owning an GMC. retired my old 1989 f150 :lol: . I love the 1500 so far, has the v6 in it. i do get an gas type knock or ping noise when starting it after it's warmed up ( not while driving, only on start up), maybe it's the cheap gas i put in it....any idea's?
Welcome to the board. Glad to see you've left the dark side.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
