Thermostat 180 vs 195
1) GMC installs a 195 degree thermostat at the factory.
2) My temp gauge reads close to 200 - 205 degrees under normal operating conditions.
Understanding that:
A) Dash mounted gauges have a "margin of error" in the 10 to 15 degree range.
B) I am not having an overheating problem.
C) The hotter an engine runs the more efficient it is (obviously up and until you begin to detonate or overheat).
Would anyone recommend a 180 thermostat over the factory 195?
What kind of performance changes would I likely note by keeping my engine cooler?
The only advantage to running the engine cooler is in the intake tract, where cooler inlet air results in a denser air/fuel charge, therefore more power from combustion.  I think that only changing your thermostat wouldn't provide a noticeable change.  Hypertech recommends buying their Power Programmer along with their Powerstat, which is a 160 stat, to take advantage of the changes to the engine temp.  Considering that your late model truck has been engineered around 195 degrees I wouldn't bother to change it.
Jeff
    BigJake
    BigJake
  • Who's Online   3 Members, 0 Anonymous, 737 Guests (See full list)
