Climate control light bulbs
This is the closest topic I could find...
Link
But this is for the radio I need to know the voltage for the solder in bulbs on the climate control panel. Is it 12 volts or 1.5 volts, those are the only two Radio Shack has so I hope it is one of them. My guess is 12 volt.
THANKS  :lurk:
Hi;
I just replaced the lamps in my 99 Silverado's climate controls. You have to use 6 volt lamps and I decided to change them all while I had it apart. I think there were 5 of them.
Okay where did you get the 6 volt bulbs? A part number would be great too.
Thanks.
Sorry I don't have a part number. I got them from an electronics shop. The original lamps have a white plastic base on them that can be removed so you can use them again and solder the new bulbs in. Its a good idea to change them all because the other ones are probably ready to blow soon.
