Redneck Last Words...
Greg
One of my buddies sent me this today to disprove this theory:
On my home one day this week I passed a house on Hacker Rd, it's one of those
houses that you can tell that several young adults live there (new found
independence). The sofa is sometimes on the porch and sometimes in the small
front yard, and various grills are scattered about. This particular day several
of them are outside, watching one of their friends standing on one foot, on
a 3 foot tall fence post doing the ole Kung Foo stance from the Karate Kid -
Beer still in one of the balancing hands :P
Saw a three hundred pound woman fall off a horse after it somersaulted over a log. She came up with drink in the right hand and smokin' with the left. Women do the darndest things. :P
  • 3 weeks later...
The famous last words of a Redneck...
Hey Ya'll watch this!
First things First
Happy Birthday Marines!!! :flag::seeya::loser:
while at a picnic for for employees at the company my wife worked at, a Vietnam error Marine had an large open mug full of beer. He had just filled his dinner plate full of all the fix'ns and was just sitting down to enjoy. well, the chair he chose to sit in was one of thsoe metal legged, canvas 'directors' chairs. the chair is in the grassy area of the yard. As he sits down the back legs sank into the ground. In what seemed like a slow motion movie, he kept going and going until the whole thing flipped over backwards. He did a sommersault roll on the ground. His entire plate of food made a perfect line in the grass from where he started to tumble to a point about 15 ft back. He stood up, did not spill one drop of the beer, and said "I hate when that happens", took a drink and went back for more food.
I should also point out that we all had been drinking for at least 3 hours up to this point. :D
Semper Fi Marines.
:chill::chill::D
