Blazin00 Posted November 2, 2004 Posted November 2, 2004 Just recently i changed the plugs, plug wires, cap, rotor, fuel filter, pcv valve. The miss only happens at an idle and the oil pressure gauge varies while its missing. Can anyone help?
GMCTruck Posted November 4, 2004 Posted November 4, 2004 could be when u change your plugs and what not you move the rotor for the dist..... and double check that everything is tight
5.3isnota327 Posted November 16, 2004 Posted November 16, 2004 Sounds to me like a bad or corroded ground, look for a spot on the intake or the back of one of the heads, there will be a bunch of black wites bolted in one place. Take them loose, clean each one and the area where they bolt and see if that helps.
