another xm radio question
:dupe: I went to order my xm add on kit part # 12498768 from a online part supplier and received an e-mail saying that the part was discontinued.I called them and spoke to someone and they told me that the kit is only compatible with the new model year (2005).according to my many hours of research the kit should fit 2003-on. am I wrong or was the parts guy I spoke with a moron ? the other question I have is what kind of wiring does the antenna have ? is it the old style plug with two wires or the new style with one wire ? I've read other posts regarding the install and it seems straight forward but I'm not real thrilled with drilling an 7/8 hole in my roof and would rather use the smaller magnetic style. I've since placed another order with a different dealer and will see if I get better results. thanks everybody and happy holidays.
truck in question is a 2003 Gmc Sierra with the bose system
Wow..... I dunno. Kit 12498768 is still showing up at both JPCUSTOMS and GMPartsDirect. However, GMPartsDirect claims the kit will not work with the U7 radio. I have no idea which radio that is.
Regarding the antenna, it is a single line feed. I'm not sure if an off-brand antenna will work since the antenna lead-in line length is figured as part of the impedance formula, I would think. Not much comment on my end regarding drilling the hole. "No pain, no gain..."
The 12498768 kit is (was???) configured for the 2003-2004 model trucks. It is still showing up on the websites so am not sure why you are being told this 2005 and discontinuation thing.
:dupe:
ok here's the latest, I contacted another online dealer that had the part for listed for $297.87 so I order it. today I get an e-mail from them saying the price has gone up to $350.00 plus shipping. so I'm back on my quest to find the part for a reasonable price. as far as what the first place told me about it not being available I think there just playing stupid or couldn't be bothered,either way they won't get my business again.
post continued,
I also found another kit offered at www.radiosandmore.com for $299.00. but in there picture it shows the same receiver and antenna I can buy in Best Buy for $49.99. I call them to try and get an explanation for the price difference and they said it has an interface harness and adaptor. I can understand that much but it must be one heck of an adaptor to add $250 to the price. anybody use this kit before? what other options do I have to install XM in my truck without adding one of those external receiver units that broadcast through a F.M modulator which I don't want to use.
To be frank, if the links above reveal that the GM XM kit is discontinued, then the only other REAL satisfactory solution is aftermarket, in spite of all the other kits that allow you to use OEM radio. I've been through this. You have your PACs and the PIEs type adapters, and basically, they get the OEM radio to pick up the satellite, but at a price of very slow performance. Heck, I have one of those around the house somewhere that I'd even give you. Works very well, but disgustingly slooooowwwwwwwww. I used it for two days and pulled it, buying the GM kit.
The "XM Direct Satellite Radio Receiver w/ GM Harness" is the only one of this genre that looks good to me. The price near $300 indicates that a lot of events are occuring to pipe a signal to the OEM radio that the OEM unit can use. If the GM kit hadn't been available, this is probably the kit I would have migrated to.
So, the other solution on getting XM into the truck is to pull the OEM radio and replace it with the many aftermarket radios that are out there. Gosh, there are many. Stop fighting it and just go with it.
Here is what mine used to look like before I removed it and installed the GM kit. I need to put it on eBay instead of letting it sit in the house. Perfectly great performance but I tired of all the bling-bling and wanted something a lot more conservative. Anyway, that is my recommendation:
Oh yeah, I'd call up any of the sales droids and let them know that you have a Bose system in the truck. I haven't worked with one of these and not sure what these kind of kits do with them.
Actually, from what I've seen & heard anyway. the XM-Direct is the most practical for a HU display model. No theftlock hassle when you transfer it to another vehicle, etc.
Chances are there's confusion with the bus systems. Several of the car models went to the CAN bus (GM-Lan) in 05, leaving accessory retrofits to that year (or later likely). But that isn't so for the trucks yet (06 and that may be just some items). So there may have been some confusion on his part.
There may be an exception to trucks with the Colorado & Canyon. Looking at some entertainment prints, it appears that the MP3 capable HU may be GM-Lan.
Coax, if length specific, would indicate that it's used as an impedance-matching conduit.
If devices at each end were the same as each other's impedance and the cable's characteristic impedance, then the only concern with the length, is the inherent loss.
I just added XMdirect to my dad's 03' yukon xl with bose it worked like a champ and only took about 1hr to do the install and have it up and running. I bought it from radios and more they sent it to me overnight for free. I reserched this for him for a long time and found this was best way to go for the factory look. :crackup:
OLERED04 , where did you mount the ant? Looking at the same kit. How long is the ant. cable? Thinking of running it out by the third brake light if cable is long enough. THANKS.
** update :devil:
I received my kit on thursday and I'm up and running. I ended up getting from P&G parts zone,the price wasn't the cheapest I found but after all the previous hassles I just wanted it done. the installation was straight forward but the included instructions were a little confusing at first regarding removing the pins from the plug. I dropped the little white plug that's supplied and was confused about that part but once I found the plug it was very easy. as far as the antenna I was not going to drill a hole in my roof and use the supplied very large and dorky looking antenna so I bought a Terk magnetic mount. the only "problem" was the plug is a little bit different. the GM receiver has two notches on the plug but the antenna only had a groove in it for one, after a little trimming of the plug on the reciever the plug fit fine and works well so far. I ran the wire down the driver's side a pillar inside the weatherstrip and down under the fender to under the hood and through a grommet in the firewall. eventually I'd like to move it to the rear of the roof and run the wire through the third brake light. but it was getting dark and was rather cold outside so it will have to do for now. if anybody wants a GM factory xm antenna and wire harness let me know.
green03sierra,
FYI. I ordered the GM XM Player Kit about three weeks ago from my local Chevrolet dealer. They installed it today into my 2003 Chevrolet 2500HD LT. Works great!!! GM recommends 1.4 hrs labor to install, so I let them do it.
Install looks as though it was factory original.
My trucks radio is the AM/FM Sereo W/CD, Cassette, and Bose Speaker System which is XM ready (had the "Band" button).
Good luck!! Traveling Fox
PS Don't worry about the hole drilling. The kit has a template and very good step by step instructions.
the install costed me nothing as I did the entire thing myself. as far as the antenna goes it does come with a nice template to lay out the holes but I just don't like the idea of drilling a hole in the roof of my truck,plus the antenna is ugly looking. the install wasn't bad at all other than me losing the supplied plug on the floor when I opened the bag with wire harness ( I didn't know it was in there). the magnetic mount antenna works very well and I get a good signal where ever I'm at so I'm happy. the only thing I don't like is the display on the radio since it doesn't have enough space it sometimes cuts off the name of a song. now that I have XM screw regular radio. one small bit of advice when you activate the system do it online since they charge you $9.99 instead of $15.00 and it doesn't take any longer to do,within ten minutes after I did the activation I was up and running
    TopBo
    TopBo
  • Who's Online   0 Members, 0 Anonymous, 1,234 Guests (See full list)
    • not all plugs will be used.  gm uses more generic harnesses that support most/all options, and if your truck doesn't have a specfiic option, the plug won't be used (commonly will have a dummy insert in the plug , or it'll be taped up, but some may just be left as is).  But it's sldo possible some p.o. has installed the wrong/cheaper parts that aren't correct for your vehicle...
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • I always drive in Sport mode. With more driving, I am finding the initial response when accelerating is much quicker now🖕 Lou
    • Is it an optical illusion in the pic or is the truck really squatting that much horribly?
    • My initial introduction was here.  It's hard to believe that I last posted in February 2013, having just deployed to Kyrgyzstan.  Since then, I've retired from the military and the 2006 Sierra SLT Z71 that first brought me to these pages was lost.  I went forward to Afghanistan in March 2013 and did a lot of sitting behind a computer on brigade staff.  Within 18 months of getting back to the States, I was selected for Drill Sergeant duty, after which I moved back to Virginia (my home state and where I served from 2004-2008).  That '06 Sierra did a lot of driving between Louisiana, Georgia, and Virginia, and ended up with nearly 320k miles by 2022.  By then, the registration had been expired for a couple of years, but the pandemic had all but eliminated tickets for such transgressions.  Admittedly too, I usually drove my wife's SUV or son's car the 2-3 times a week I had to report to work.  Teleworking sure was fun while it lasted.   I started my retirement leave four years ago and stored the Sierra at my sister's house.  A big mess was made when her fiancé passed while she was taking care of business out-of-state in late-2024, and his son pretty much mismanaged everything to do with the estate.  Even so, I was assured that my truck was safe... until it wasn't.  I found out that my truck had been scrapped about four months after the son took over everything.  There's nothing I could do; I'm 1000 miles away and it was technically abandoned property since he'd even trespassed my sister from her own house (she had no claim to it as she wasn't married, and the fiancé was the sole owner).     Anyway, today I got my second Sierra.  This is a 2010 SLE 2WB CCSB with a little over 200k miles on it.  It's got the 5.3L I'm familiar with and should handle what I need it for.  Hauling stuff that won't fit in the Transit Connect (yep, I sold out, but that's the wife's vehicle) and towing a few times a year tops.  The price seemed decent, considering how much people sell their trucks for in the Deep South: $4500.  I've seen similar trucks listed for more than double that.  I got it from a coworker who left his tag on until we transfer the title next week (Louisiana requires a notary for transfers), so I've been driving it all day.  The rear speakers don't work, which is one of the things that brought me back to these forums earlier.  I can't say how active I'll be as a poster, but I'll be scouring the archives while I find out every little thing I can about the 2010s and particular nuances/problems with my truck.   It's definitely not a GMC, but I got another Willys Jeep a few months back as well, so I'm almost at the same place I was when I first joined gm-trucks.com.  My old 1960 DJ3A was sold back around 2010 or 2011; my current Jeep is a 1946 CJ2A.  So, I've got a slightly newer GMC and a much older Jeep.  I kind of wish I still had that F-250 I had way back when too.  The Dakota is long gone and was technically my brother's truck, though I had it registered and insured.  The F-250 had to go when my grandmother's house was foreclosed on due to mismanagement around 2012 or so.     Hopefully anyone that made it this far isn't too annoyed.  I tend to be long-winded, but I'll be doing more reading than posting in the coming months.
