Gm-truck Member Calander?
SlamminL5s
We Should Find A Way To Get A Big Voting Going On And Pick 12 Trucks (that have pics) to make a club calandar... sorta to help support the club...
yeah too bad its already january!
This didn't happen to stem from the BMW enthusiast calender I just headed up over at roadfly did it? the sig pic I had for a month?
take my advice start around september. it takes at least 2 months to get the pics in and the voting started. another 2 weeks to get the pictures set up correcly, and another 3 weeks to find a place to priont it at and get all the orders in, then more time to get the money sent to you!
we started in mid october, we sqeuak by getting it done the second week in december(we used every spare minute we had on it). it woulda been inhome by december 31st until the press broke.... THE FIRST TIME!!!
by the way the printing press thing was destroyed while they were triyng to repair it.......the calender was the next thing they were to do.
whenever you guys decide to start it up, I'll be happy to lend "advice" since I've been through this before! :crackup:
So now we have a trademark for our calender "feburary thru january" lol.
We do one for the Turbo Buicks. We start picking cars like September and put a bunch of pics on a site. Then everyone votes on the top 12. Does take some time but it's nice to have your car/truck on the wall in the office! :chevy::crackup:
Work is already in progress for 2006. The problem is you have to get orders in by like August to get good pricing.
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
