pulling a vehicle out: do it in R or D?
Was wondering if it makes any difference if I use my tow hooks in the front to pull a vehicle out using reverse, or if I should just attatch it to my class 3 receiver in the rear and use drive. Are there pros and cons to each method? Does it matter stress wise on the transmission or the engine which method someone uses?
1998 Z71 5.7L
I would drive forward and use 1. I am almost posative that 1st gear in the 4L60E is lower than reverse. Also those tow hooks you have on the front are for emergencies only. They should be used only when you have to be pulled out from the front end. I have seen these hooks snap before. It is not pretty. They are cast iron, so they are weak and non-forgiving. Use a reciever hitch on the rear that has the large clevace or a reciever with a welded eye. Even a reciever with the tow strap looped over the ball is better than tying to the recovery hooks. Besides if the chain or strap brakes I would rather have a dent in my tailgate than in my forehead.
I guess I'm not with the majority here. I pretty much always use the front of the truck and pull backwards.
I use 4-low on the 5 speed in reverse, so gear reduction helps a lot. I also don't yank, just ease up tight and increase tension slowly. If the person being pulled spins his tires wildly, I let off, drive forward, unhook, and leave. I ain't gonna pull out a moron like that.
I also like the fact that I can 'wiggle' the truck side to side if I need to hunt for an area with better traction.
To each his own... :)
Your rear differential and driveshaft are able to take far more abuse than the front. Check out the size difference! Reverse gear is usually much more fragile than a forward gear on a manual transmission. Can't speak for an automatic.
If the pull is a light one, such as a small vehicle on the level, it probably wouldn't really matter. If it's a hard pull, such as a full-size vehicle out of an incline, face the vehicle away from it.
1998 Z71 5.7L
Pulling from the tow hooks is putting a real strain on the frame. I have seen vehicles that pulled a vehicle actually pull one rail and cause the truck to drive side track. Best is to pull from the platform hitch since its equal distribution on the frame. And all transmissions are stronger in there forward gears. :)
If it's a hard pull, go with foward. I broke an 18,000# rated tow strap before, and was glad the back of the truck took the abuse. You can also see where your heading better in foward.
Reverse should work if it's a light pull, like a car stuck in snow, IMO.
Well this is what someone with my off road credentials would recommend. Only use your reciever attached to a clevis and use a kinetic recovery rope with looped ends (no metal hooks). This is a pretty foolproof method as the rope gives a little so it will not be as hard on your truck and springs back almost like a bungee helping free the stuck vehicle. I would never use a chain or one of the front hooks to yank someone out of the mud. Now, I will mention that I have no off road credentials, which is why this is the perfect method! :) It is very hard to damage your truck doing it this way. I am sure that professional off roaders and tow people know how to properly use front tow hooks and a chain, or metal ended straps. I have just seen too many people who dont know what they are doing get caught up in the moment trying to jerk someone out only to find a hook come flying through their back window. Personally, I would never use a method that could potentially damage your truck. Also, I have heard you should never attach a rope to a hitch ball.
I always use my hitch and drive forward.....My license plate and I can attest to having ropes snap, it's not pretty, and I am pretty d**n sure that had I not been using the hitch, I would be the proud new owner of a new radiator......I also like the kintetic tow straps that someone mentioned....not sure if we're thinking of the same thing...but they have a bit a stretch to them...so it simulates yanking.....I usually do it in 4 lo 1st gear and just use brute power(but no wheel spinning and no yanking)......Of course I only do it in sand...never tried snow.
All that being said.......if it's some jackass in a rental AWD subaru......all bets are off.......then it's just time for fun.....
Most everyone has said hook from the rear and drive forward. I would agree with the logic. As an interesting note, when I had my Jeep, most other Jeepers said the opposite: hook from the front and back up. I don't know if that is a Jeep thing, but I had more success that way with my Jeep. With my GMC, definately use the rear hitch to mount the strap.
On the Allison, reverse is a lower gear than 1st, so in that aspect it may help. However I do agree the tow hitch and the rear axle are built more for pulling than the front. (altho Ford's commercial shows them pulling 19K backwards with the tow hooks). I have done both ways, thankfully with no bad results.
I would pull from the back. The main reason being, it is easier on the frame, and the hitch is stronger. Also, like someone said, if the rope breaks I'd rather have it hit my truck then me.
Food for thought...
anyone ever seen the inside of their differentials? The teeth are curved. They're meant to take abuse going forward- not reverse. I'd be weary trying to pull a lot in reverse thinking about the damage to the diffs alone.
    250.3k
    BDS my HD
    BDS my HD
  • Who's Online   1 Member, 0 Anonymous, 449 Guests (See full list)
    • Hello hello looking forward to expanding my knowledge of the 2026 2500 HD that I just bought.   Truck has 3500 miles on it four-wheel-drive crew cab and I’m about to put a 6 1/2 inch BDS lift on it 18 x 10 -25 offset with 37’s   Already have the wheels and tires just waiting on the lift install in about three weeks   Question what surprises am I not gonna be happy with?  I’m not new to lifted trucks so I know that acceleration towing gas mileage all that is affected..   Question is those of you that have this truck this powertrain with a 10 speed Allison and have done the mods that I’m doing,,, how bad is it? Is that Allison constantly gonna be hunting for the right gear to go into? And what about towing, acceleration, fuel consumption as mentioned?    Lastly how come I can’t find any ring pinion gear set up for these axles and when could I expect to see them?   I apologize if there’s any typos I’m doing speech to text on my iPhone.
    • I've got a 2013 2500 6.0L Flexfuel. Drove the truck earlier today with no issues. Went to run an errand tonight and noticed key fob wouldn't work. Figured battery was dead, so replaced fob batter. Still wasn't working. Grabbed my other set of keys with the other fob and that one wasn't working either. So I manually unlock truck and insert key. Interior lights come on, dashboard lights up, turn key and truck starts. Turn truck off, like a moron, and try starting again. This time no crank, no click, no nothing. Lights still come on and dash lights up, but now I'm getting a service 4wheel drive, service tire monitor, etc. Check voltage on battery and Im showing 12.2v. Throw my battery charger on it and give it 15 mins and try starting again. But still no crank no start. Decide maybe its a bad battery, run to autozone grab a new one and put it in. Same issue. Disconnect battery and let it sit for 15 mins. Try again and still nothing. I had managed to roll the windows down earlier as its a humid night, but now I can't get them to roll up. Power locks are also not working now. Then randomly I try the key again, and it fires right up. Immediately I roll up the windows as we have nothing but rain forecast this week. I shut it back off wait 30 seconds and start up again. Worked a 2nd time. So turn it off, start putting things back together. Try one more time, and back to no crank no start. And now the car alarm starts going off. Had to disconnect battery and leave it that way for the night as I don't think my neighbors would appreciate my alarm going off again tonight. Any thoughts or help would be appreciated.
    • No one will care for you like you care for you. Do what you can for as long as you can. IMHO of course.
    • How about them NICKS!!!
    • Hi there.  Long time lurker, first post.    i have read the previous posts regarding the water ingress problem with this emblem.  I bought my 1500 SLT the  summer of 2025 new and after reading the MANY problems with these emblems failing I decided to install one anyways.  As per a YouTube video, I sealed ( or tried to) this sign with silicone sealant around the outer perimeter joint and the holes that were already somewhat sealed on the rear plate of the emblem.  And installed the connector assembly using dielectric grease on the connectors. The installation looked great and worked well for about 4 months……then FAILURE.  Grrrrrr…… I live in the great white north and wash my truck weekly in an automatic car wash  to keep the salt off.  Let me tell you that removing the old, failed emblem is a whole different animal than removing the OEM individual letters without removing the grill assembly. Mainly because the illuminated logo is built differently than the original letters which  you can remove the red surface lettering with a knife or some kind of blade which gives access to the tabs which hold the logo onto the grill. So I had to essentially destroyed the old emblem to remove it. Doing so killed my chance of doing somekind of autopsy on the failed , old logo.  But there was plenty of water inside when I ripped it apart.  Prior to installing the new assembly I tried it with the old harness and it works fine.   Does anyone have any insight as to where the water is getting into this emblem? I intend to seal the new logo with slow curing epoxy this time around using a syringe.  I think this newer emblem may be an updated unit which I hope GM got the vendor to fix. It has an October 2025 date on it.    If this one  fails,  I am just going to revert back to the non-illuminated letters….AFTER PULLING THE GRILL.    Any thoughts on sealing with epoxy would be appreciated. Thx!   Doug
