? for GM-TECH
Hey, I don't want to start world war 3, just a question. Some people have said to remove the fuse in the cab to disable the DRL's. My concern is will this cause any harm down the circuiut like to the relay for the DRL's? Thanks for any info!!
Simply removing a fuse to disable the DRLs only works in older models. I don't remember the years exactly... '95-98??
In any case, removing a fuse for anything can cause no harm that I can think of. You're simply removing power from that circuit.
Thanks
are you sure about that, tech? I've removed drl fuse on my last to nbs chevy's.
I don't want to start a shouting match either but all you have to do is remove a fuse in the underhood electrical center and your good to go,I have done this with my '99 and my '04. :thumbs:
No, I'm not sure of anything when it comes to making modifications. :thumbs:
I keep forgetting that the new body style C/K's use separate DRL's, unlike most of our other models that use the headlights. So yeah, on the C/K's that have separate DRL lights, just pulling a fuse should do just fine.
I was thinking of the older body styles that used the headlights for the DRLs. On those, you could just pull a fuse too. Most that use the headlights are not that easy.
cool
Yeah I dont see why you would want to turn them off either. Unless you have the 2000 or 2001 models that always seem to have one burned out. Other than that, why would it bother you enough to turn them off? Im curious of the responses on this one...
I decided to pull the fuse on mine (2001), I personally dont like the DRL look on any vehicle. The fuse for mine is under the hood in the electrical system box. To each his own!
As a so called "PROFFESIONAL DRIVER" I really like the DRLs on all vehicles, THEY DO improve the visibility of the vehicle...especially those who dont turn their headlights on in foul weather :D:wtf:
But thats just my $.02
The original post was A TECHNICAL QUESTION. Wether or not someone likes them or not is for another forum. Because I dont like them dosent make my opinion BS!
Hey jhm, dont get your feathers so ruffled! Nobody cares if you want them on or off, we're just voicing our perspective on the deal! You asked on a public forum so your gonna hear it whether you like it or not! :D Anyway, I dont wish to argue with you over this, its your decision and if thats what you want, then by all means, do it. I was just curious of the reason why, but now I dont care.... :wtf:
This is why I'm never posting in a thread that has anything to do with DRL's again!!,I have never seen people get so upset about such a little thing as this :wtf: ,You either want them on or you want them off.(I choose off)
Roostman, Like I said initially, I dont want to start WW3 all I wanted was a reply from somebody who knew for a fact if any electrical damage could result from pulling the fuse, I would rather ask than find out later. I wasn't interested in someone telling me I was going to be run over by a Peterbilt, or my opinion is BS. As I said, "to each his own".
    HWN808
    HWN808
  • Who's Online   7 Members, 0 Anonymous, 995 Guests (See full list)
    • https://www.gm-trucks.com/why-gm-chose-0w-30-gen-6-v8-oil/   The swing back to reality continues…
    • Diesel $5.42 at the truck stop on the hi-way
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
