leaking from rear windshield
Whenever it rains I'm getting watter coming in from the top driver side of the rear windshield. Has anyone else had this problem and does anyone know of a fix? Thanks
Do you have the sliding rear window? I had mine replaced 3 times under warranty for the same problem. The plastic window frame would crack in the upper corners and water would pour in. They finally installed an aftermarket one with a metal frame which has been pretty good for about 3 years...makes some funny thunk noises when cold, and I just found a small part of the seal starting to leak, but nothing major. I can fix the small seal issue myself.
Both of the latches on my rear windows are broken but I don't seem to have any leaking there. This leaking is happening at the top corner on the driver side of the rear windshield. My extended warranty was through warrantygold.com so I'm pretty well screwed now. Any idea how much $$ it is to replace those rear windows? I don't think you can just get those latches fixed. The latches on mine no longer catch in the middle, but keep going inwards which pops the window back out a little bit which allows a lot of wind noise. Thanks
