Factory Speakers Blow
KG4LHQ
Hey - Tried to turn the Kenwood KDC-X559 Up today in volume and the d**n front speakers started screaching like their busted. Played with the fader and the backs are ok but the fronts are like fingernails on a chalkboard. THEY SUCK! LOL
Anyways. Here's my Plan - I'm on Ebay right now looking at getting these
Rockford Fosgate FRC4306 - 3 Way 6.5 Speakers
From what I understand their pretty good front speakers. Is that all I need?
From what I understand there are tweeters or whatever I have no clue what all that terminology means. Help would be appreciated!
Thanks
My back is a 1 Rockford Fosgate P1 Punch with a California Profile 200 Amp 2 CH 12" with Factory speakers in the back
:chevy::D:lol:
In my opinion speakers from 10$ to 80$ are all the same. 80$ to 150$ are pretty much the same. 150$ and up and your getting into the goodstuff. The middle range is good enough for 98% of us. But most of those can all sound the same if your running off a deck. Running off of a good amp can really bring out the differences, if you have a picky ear. Which most people do not.
I would say stick to brand names you like, and that will back up a warrenty.
RockFord Fosgate, is like one of the top speakers and amp builders there are. Now I only say that because thats what your looking at. I'm not trying to start a brand war with anyone.
But check out www.crutchfield.com You can learn a lot there, if you havn't been there before.
I have Rockford Fosgate 6.5's in my doors also...I think that they're 3206's or something like that. Pretty sure they're 2-way speakers. I'm very happy with them, especially after the junk paper factory speakers.
    • Thanks!  I figured as such; GM and other manufacturers have used standard parts and harnesses across trim levels and such for decades.  I pulled the blank accessory cover off of my commuter van (a 2016 or so Chevy 15-passenger) years ago and found the plug for a USB outlet.  It wasn't connected to anything, though (I tried swapping in an outlet from another van).  I was a GM Tech years ago (late-90s) and was pretty familiar with my 2006.  I might be wrong, but I view newer vehicles (pretty much anything made in the past 20 years) as being a lot more plug and play.  Meaning, more unused wires and plugs unless you have the Mack Daddy of vehicles.
    • not all plugs will be used.  gm uses more generic harnesses that support most/all options, and if your truck doesn't have a specfiic option, the plug won't be used (commonly will have a dummy insert in the plug , or it'll be taped up, but some may just be left as is).  But it's sldo possible some p.o. has installed the wrong/cheaper parts that aren't correct for your vehicle...
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • I always drive in Sport mode. With more driving, I am finding the initial response when accelerating is much quicker now🖕 Lou
