Direction flasher - help find
'88 Chevy Scottsdale 2500 4x4
The turn signals are not working. The bulbs are fine. The fuse is fine. I think it's the directional flasher, but I can't find where it is located on the truck. I found the hazard flasher. I torn half the dash apart looking for it to no avail.
Anyone got a clue?
If it's anything like my '92 was, it should be up under the dash to the left of the steering column if I remember correctly. Plugged into the harness.
If you know someone who has one that works in an 88-98 style, crawl under there while the T/S are flashing and listen for it. It's a lot easier to find that way.
On my '95 its just to the right of the steering colum, tucked up under the dash panel over the lower dash support. If I remember correctly on the '88 Siverado I once owned it was located in the same area but up higher, almost behind the stereo head unit...hope this helps
Could this be it? I kept looking for a simple two connector thermal unit. I haven't been able to reference the numbers printed on it as the flasher.
That looks like one to me!
I'm like you though, I don't recall them having 3 prongs, only 2. I also remember them being round.
Might be an electronic flasher, which would explain the 3 prongs.
just label me a dumba$$ :chill:
that was it, a electronic flasher...was right out in the open, behind the parking brake, on the firewall. it was one of the first things I looked at.
jeez what a boob.
:withstupid:
