Big towing mishap, OUCH.
Well in one of the more messed up situations of recent memory my GF made a quick mess of a recently purchased prodject car, a Ford Taurus SHO, last night.
I wanted to tow it home from the shop last night so I could work on it here at the house over the weekend. It has oil fouled plug wires from leaking valve covers. Being as how I had ruined convertors on two separate occaisions with my first SHO in similar circumstances I wasn't going to drive this one like that. It's a short 8 mile trip and she was all over being able to do it, no problem. "Oh I take that seriously. I used to help Kerry do that all the time." Etc. So we took the truck over there and I hitched them together with about 18" of strap. I showed her in the car, all seemed good so I drive off. We got about a quarter mile up the highway doing about 45 and I had to slow for the first traffic light. I started slowing way early and gently, waiting for her to hit the brakes and then CRUNCH. I was just kept driving along like "This didn't just happen." So I figure out that the SHO is hooked hard to the rear bumper of the truck and just stop in the center lane. I get out to veiw what was a perfectly straight '91 SHO wadded up big time against the tow box of the truck. It's a total loss. I asked her what happened and she says the brakes didn't work. I just shook my head and said, "That's the clutch, oh well so much for that." She's an automatic type, who I've explained how the standard works to. Heck a while back she took the RX7 around the nieghborhood to try it out, without my knowledge, and supposidly did fine. But it wasn't enough in the dark, first time in this car to help her figure it out when she pushed the clutch in and the car just kept on rolling. Panic ensued , not much else happened, then the crunch.
So we're out about $720 I've spent aquiring the car and getting parts, I can send about $120 worth back. I scrounged all though Christmas season to pay bills, buy gifts, and purchase this SHO. I was all behind for the last month in bills just for this.
I'm taking it pretty well, I think my GF expected me to flip out, but I don't see any point in it. She made a mistake, I should have known better. Live and learn.
Vernon
We had a customer buy a new Porsche for his Wife, she was learning to drive a standard shift and wanted to drive her new Porsche home herself...he was driving the Sons leased VW (due to be turned in) with the Wife behind him in the Porsche...they got 1/4 down the road to a stop sign...guess what happened..yup, got the pedals mixed up and she slammed the VW...True Story.
Wow. I'm a pushover when it comes to my girlfriend, but I know I'd be fuming on the inside! My truck is a 5 speed. When I bought it, I had never driven a standard before. I had someone drive it to my house for me. After I figured out that it had the heavy duty 5 speed in it and 1st gear was not a normal driving gear, it took me 20 min to get the hang of it.
Ow! Man I hate that "crunch" sound!!
Hope it didn't tear up anything in your truck...
Sorry to hear about your misfortune, and I'm glad to hear you handled it well. Hang in there - Good things come to good people like you eventually.
:cool:
I feel for ya. What's done is done and there is nothing you can do about it.....except not trust her driving skills anymore.
BTW, Those Yamaha V-6's have a cool looking intake!!
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
