The Avalanche Hits Home!!!
:D  :)  :sigh:  :D  :P  :)  :D  :blush:
Well, the wait is over.  For the last 36 hours I have been the proud owner of a 2002 Avalanche 2500.  She is home, and I am movin' in!  I have begun the long and painfull process of installing;
Trainler Brake Controller
Fog/Driving Lights (PIAA Dual Sports)
PIAA Super White Bulbs
Dual Band Amatuer Radio
Aux. Electrical Accessory Switching Console
iPAQ Pocket PC
GPS for iPAQ
Ventvisors
Molded Mud Flaps
Bugflector II
Husky Liners
Stars of Life (x2)
Cell Phone Handsfree
Seat Protector
Alarm System w/ Remote/Automatic Start
Assorted Bits and pieces of lifes flotsam and jetsam that we seem to need in our cars
A Nice Set of BFG All Terrain T/A ko's (265's??)
and when available...
Smittybilt Side Step Bars (Black)
Smittybilt Outland Sport Front Guard
Well, that should get me started anyway.  Sorry I didn't let you all know sooner, was out driving around with the following assorted facial expressions, in no particular order...
:love:  :blush:  :devil:  :)  :P  :D  :blush:  :devil:  :devil:  :P
I'll do some pic's once it looks something different than a showroom model.
HEHEHEHEHEHEH, maybe one more drive before bed......... :devil:
Scott  :stupid:
Scott,  Good for you !  Hey man keep us
posted on that 8.1 and 480e (?) combo.
Am interested on how the non Allie ones
will do..............Geo
Cool...
Congrats, I know it must have been an agonizingly long wait.  I am looking forward to some pics, and some impressions of the 8.1L in the Av.  Did you get 3.73's or 4.10s or is there even a choice?  I'm curious as to what mpg's you'll get...
Keep us informed.
Thanks guys, nice to be able to share with other truckheads!! My wife isn't into cars/trucks, so my excitement is lost on her.
Shaners, Yes, it's the 8.1, and it is more fun than should be legal. Come to think of it, the way I have been bombing around, it probably isn't!!! I had a choice of 3.73's but went 4.10 for the extra tow cap.  I am not going to check gas miliage until after the breakin period, not sure my heart could handle the numbers!  :notice:
I will do some pic's next week after the mud flaps, vent visors, and Bugflector are on.
Until then,
Scott
Quote from ryr8828, posted on Oct. 17 2001,6:37
Avalanche with an 8.1L should be a serious BEAST. I am interested to hear what happens when you floor it. After a proper break-in, of course.
I would guess it will sit in one place for quite awhile before slowly pulling out of the cloud of smoke!!!  LOL
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
