Wiring a new head unit
Guest 007FL
Guest 007FL
I'm wiring in a new head unit. I need to know the wire colors on the stock harness for:
1. switched power
2. constant power
3. lights/dim
4. ground
Thanks
Guest 007FL
1. switched power
2. constant power
3. lights/dim
4. ground
Thanks
come on guys, a little help here.
I know someone knows the stock wiring code....
hmmmm?
1. switched power - there is none (switching is done through the data bus wire)
2. constant power - Orange (the larger one in A1 position)
3. lights/dim   - there is none (lights and dimming is done through the data bus wire)
4. ground - black with white tracer
Thanks
See quote box above, I've added the wire colors for 03-05
Guest 007FL
Thanks
Thanks BBSilverado, I'll take it from there.
:cheers::sick::thumbs:
