GOt hit by a silvy
SnakeEyeSS
dump close to 10K to restore a classic Bimmer to almost perfection........no good deed goes unpunished..... :fume:
good news: it was under 5 MPH and there is no damage.:wtf:
It was 81st and Memorial in Tulsa, traffic was inch up cause the light turned green, but I Was way back in the line sand the van in front of me stopped, so I did too......BAM.... look up and a black 04 Silverado that'd I'd been around for the last5 miles hit me. the two guys in the truck had the "uh oh" look....I was fraking mad:smash: . between the 15 I got hit and the 7 seconds it took me to slam my hand on the hsteering wheel and get out the car with I wouldn't be suprised if blood was shooting out my ears I was so angry:smash: the driver could tell I was hacked:smash: . We walked to our bumpers, perfect dead on hit, and our bumpers lined up perfectly. I immediately got under the car(and for you Tulsa people yes I was still dead smack in the middle of Memorial ion the ground under my car, on the 2nd busiest road in NE oklahoma. you guys KNOW I dedicated.....and the driver slight choks was slightly "clean". no "frame" damage, no bends, unnatural creases in bumer bodwork or unibody, rear apron or anything......so I just told him it looked like he got lucky, nothing wrong, don't worry about it....he was like "hey thanks bro(or "man, or something" then shook my handsorta, that new age grab the hand and lean in thing).......... :D
then I noticed he turn into a parking lot and waited until I had gone down a littler further so he souldn't be near me again. I told you I was mad. or else the thought of hitting a pristine BMW for the second time was not a good thought. Well, I was in uniform also....... :nopity:
oh, he had a holographic, massive JL Audio vynil on the back window.....it was black, extended cab, short bed.....for you tulsa guys to get out of the same lane from.......
Was it a punk kid? Because I belive I have seen that truck on Memorial several times. (Memorial is the 2nd busiest st. in all of OK behind 71 st.) I think he lives in one of the apt. complexes right off of Memorial. I won't get to specific on here about where.
But any ways.
That sucks man, glad to hear it wasn't a major hit.
But honestly hitting someone at a GREEN LIGHT is pretty freakin retarded. :wtf:
Be glad it wasn't the 69. :nopity:
That is one reason I'm not in a hurry to finish the Impala, I'd be scared to drive it. At least now it doesn't matter so much since it needs so much work. Still isn't right.
Glad no one was hurt and the damage was light.
