Dex-Cool Beleive it or not!!
I had been having problems with my low coolant light coming on and had the coolant smell in the cab. I got ticked off with having to add coolant all the time so I thought that I would do a cooling system flush and refill, it has been about 90 days since I did that and my coolant light came on only one time and that was the next day when I needed to top off the tank. So if anyone is having problems losing coolant they may want to try this. :cheers:
That was a thought as to why I was losing coolant. But after the flush and refill to have only added about 2 cups the next day after doing the work I would say that the gaskets are not a problem.
Classic GM DeathCool and intake manifold malady.
Well documented over at the Suburban forum and on my buddies Suburban/GM Truck info site at: #1 Son's place (andy lim) Look in the sections for intake manifold and coolant.
Also could be the heater hose quick connects. They rot out, but a 99 should have the "new" OEM fittings from the factory.
Another is the heater valve on the passenger side hose.
