Nav install done
s-t-p
I got my Nav unit installed thanks to all the help here on these forums. I took it in to the dealer for the theftlock deactivation. Now there is a problem that hopefully someone here can help me with.
When I took it in to the dealer, the service tech said they may not be able to do it because sometimes the unit will not let them relearn a new VIN. They were able to unlock the unit but told me there were three codes that the computer was coming up with that indicated some sort of error or incompatibility and that the unlock may not last. They said that means at any time the unit may reset to the "theftlock activated" state. Well, I crossed my fingers and left. I tested the navigation and it seemed to work. When I stopped somewhere and turned off the vehicle, when I started up again, the navigation came up fine and then the message returned "theftlock activated" and the system turned off, or at least the theftlock activated message stayed on. When I got home and shut off the vehicle, when I restarted the nav unit came on fine and seemed to stay on. I haven't retried it again to see what it does.
Does anyone have any idea what is going on? The dealer said it may act up because the navigation was not originally an option on the '03 Escalade, and since the unit came out of an '04 Yukon Denali that the Bose premium sound system in my Escalade may not know what is going on and getting confused. I didn't really understand that because my model of Escalade did have the navigation as an option, at least it has the Y91 option with the Bose lux amp premium sound system, 6 disc CD changer, rear seat entertainment, everything I read about that said that was what I needed for the system to work in my Escalade. And it does work, everything was pretty much plug and play as far as all the wiring and connectors go, I didn't have to do any special rewiring at all to get it to work. The startup splash screen on the nav unit even updated and said "Cadillac Sound by Bose" even though the original splash screen just said "Delphi". So what is the dealer referring to about incompatabilities?
Another question, the nav unit has the XM radio option but my Escalade did not have XM. On the Nav unit now, there seems to be no selection for XM. Should XM be available even though the original system had no XM?
A final question, on my original unit I had an adapter installed that plugged into the CD changer controller (plug in the back of the unit) to add Aux inputs for my mp3 player. When "Band" was pressed the new auxillary inputs showed up. Now on my nav unit the auxillary inputs are not there, although the adapter is still plugged in and the CD changer is still disabled (as it was in the original unit). Does anyone know if I can still use the auxillary inputs adapter from my original unit, or will I have to remove it and just reconnect the CD changer?
The XM will only show up if you have the XM tuner installed and connected. XM is a separate unit that mounts behind the glove box and connects in through the input connector (the 12 pin connector where you put your aux input adapter)
Do you still have that original 12 pin connector connected to the input adapter?
does your reas seat entertainment work? your cd changer should still work even with the input adapter.
What model number is your nav unit and what brand and model is your input adapter?
The auxiliary input adapter is a GM12-AUX made by PIE. I was told it basically takes over the CD changer control so that when you press the BAND button you get a setting that says AUX1 or AUX2 instead of CD. For that reason, I suppose, it disables the CD changer. The adapter is plugged into the original 12-pin connector in a Y-type configuration. The rear seat entertainment still works with the wireless audio but I cannot control the audio with the nav radio controls-the controls show up on the nav radio, but there is no audio from the RSE through the Bose speakers from the RSE. Radio works fine, the only things that show up on BAND is AM FM1 and FM2, there is no longer any AUX1 AUX2 options on BAND and no CD option but the adapter is still plugged into the 12-pin harness.
My DVD nav unit is GM factory unit made by Delphi part number 15204335.
Sounds like I do not have an XM tuner so there is no option for it on the nav radio.
The nav unit you have should work with everything you have.
The reason you RSE audio and CD changer doesn't work is because of two reasons:
1) the factory 12 pin connector is not plugged into the "y" adapter.
2) the adapter is defective or not the correct one, PIE has had some problems with them.
make sure you have the right input adapter, some where made for applications with slave devices and some where made for applications with non.
I would look at the adapters made by PAC, there has been less problems with them, they even have a nice one now that works great for I-pods.
I removed the auxiliary input adapter and everything works as it should now. I noticed on the input adapter that the factory 12-pin connector plugged into the adapter 12-pin connector, only the adapter 12-pin connector only uses 8 of the 12 pins. A 12-pin connector comes out of the adapter box and plugs into the back of the nav radio but there are also 2 wires that come out of the adapter box and tapped into two wires in the 24-pin connector (a solid orange wire and a black with white stripe wire in the 24-pin connector. I would assume this is probably the wrong adapter for my vehicle.
If I want to add auxiliary inputs to the nav radio, should I consider the AAI-GM12 or the AAI-GM24 v2?
Yes, that is the adapter for use with no slave devices, that is why none of your slave devices worked (I.E. the RSE,and CDX)
Thanks for all your help. I suppose if I want something right, I have to do it myself. Those guys at Car Toys didn't seem to know what they were doing (they sold the adapter to me and installed it).
Looks like I should give the AAI-GM12 a look see. I don't use an iPod, I have a different mp3 player.
    ncleg
    ncleg
  • Who's Online   7 Members, 0 Anonymous, 744 Guests (See full list)
    • I have a Retrax pro that I first had on my 2020 chevy and transferred it to my current GMC.  It stays in the garage most of the time, so hard for me to judge it's long term weather resistance.  It still works perfectly, been very durable.  It doesn't see oil patch usage, but it's not a mall queen.  It keeps most things mostly dry (small leaks) and the security of it is enough to slow someone down but not keep them out for long.  I would buy one again, it works for me.
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • The recall is for exactly this issue - those drain holes combined with the limited environmental capability of the tailgate electronics card inside the tailgate were a problem. The “safety issue” was the potential for the tailgate to spontaneously open, but all kinds of tailgate misbehavior can occur from water contamination of that control card.    There is no real fix yet. The initial recall just disabled the tailgate. Later, when parts became available, they would replace bad parts with new parts of the same bad design. My dealer is going nuts because the few times I let them get their hands on my truck, my tailgate is off due to a slide-in camper installation. They really want to cut my tailgate wires, but I won’t give them the chance. I will let them get their dirty hands on it when a real fix (redesign) is available.  My tailgate, which works just fine with sealant plugging the drain holes, will remain safe in a dry storage crate until then.
    • Yes your absolutely right, I been looking at the 4 inch BDS one and it acutely states you can use the stock 20’s just not the 17’s or 18’s, I also didn’t realize that with my 275/60r20 stock wheels I’m already running 33 inch diameter wheel setup lol so I can just run my stock wheels and tires atleast to start.
    • I would expect that to be lift-kit dependent.  If the kit has interference issues w stock wheels, then the kit/manufacturer should indicate that somewhere.
