Where can I get rood marker lamps for my HD?
You can get them here. http://www.cabelas.com/cabelas/en/template...requestid=22782 Or here. http://www.autobarn.net/higfivligkit.html
Ive installed 5 sets on differant trucks and there not hard at all to install just the head liner has to come down but thats not hard to drop,just make sure you get the measurments right,I went to the dealer and got the mesurements off of one of there trucks off the lot,as far as the power hookup I ran the main power wire to the front parking lamp (not the turn signal hehe) and sliced it there.Do use sylacone around the bottom of the gasket that goes down on the roof as some of the factory ones are leaking there also,just to save you some trouble, plus I also pulled the bulds out of the new set and put some bulb grease in the sockets and make sure you wipe any excess bulb grease off the bulbs when you reinstal them in the sockets.Oh and another thing the supplyed screws rust quick just get the same size screws in stainless and use them,you can always use some black touch-up paint on the screw heads so you dont see them.
