Help with NAV Install
Ok, so I have read thru the 30 some pages of the Nav install thread and i am now MORE confused than when I started. I will try and explain my situation... I am trying to find the part number of the nav head unit that will be almost plug and play, I do not want the external cd changer, all I want is the nav, onstar, xm and steering wheel controls to work, I dont want to mess with changing the amps or any of that. Is this possible?
I have a 2005 Chevy Silverado 2500hd LT, it has the bose/6 disc system, but I could not find the y91 option on the glove box.
Please help.
Jesse
Please help.
Jesse
Unfortunately I can't help you with the nav radio part number for your amp situation, I forgot those numbers long ago.
However, whenever you get the right radio for whatever amp'ed application you have, the radio will know that you have Onstar, XM and steering wheel controls. All of those items are plug and play.
Please help.
Jesse
if you have the UQ7, which i'm sure you do, the 15229287 will work on your truck.
Please help.
Jesse
try this a friend just bought one of these from this seller, add the vss wire plug & play, He did not even have to have the vin cleared allthough the next one might have to be cleared, this seller has sold several of these recently, I am doing a lux unit for my truck, good luck Bob
http://cgi.ebay.com/ebaymotors/GM-HUMMER-D...1QQcmdZViewItem
UQ7 is non-LUX Bose amp...I got the same thing.
So you need to order the non-LUX Navi unit (part number mentioned above), plug it in and your rolling.
