Happy Birthday
R Dogg 56
Thanks guys. I actually spent today at day 2 of a 2 day Emergency Response Operations Course. Today we did some braking exercises then ran a Toyota Camry on some foam on a skid pad. That was definitely an experience. We wrapped up today's driving with 2 pursuit scenarios each- those being done in the Crown Vics for us, and Impalas for another department that was there. Speaking of the Chevy, we did some figure 8 exercise yesterday and the guys running the Impalas would actually get 1 of the rear wheels off the ground in some of the curves due to the weight transfer.
Happy birthday!!! When was it? Mine was 9/28!
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
