Stock 255/70/16 versus 265/75/16
Truck: 2004 Silverado 1/2 ton Crew 2 Wheel Drive 3.73 gears
I am considering upgrading from the current 255/70's to 265/75's.
The rev's per mile is 5% less. Will this cause a Big Hit in the MPG or Power department?
Also any rub issues on a 2 WD Silverado?
Thanks in advance.....
Here's some good info:
Stock Tire - 255/70R16 Tire 1 - 265/75R16
Section Width: 10.03 in 255 mm Section Width: 10.43 in 265 mm
Rim Diameter: 16 in 406.4 mm Rim Diameter: 16 in 406.4 mm
Rim Width Range: 6.5 - 8 in Rim Width Range: 7 - 8 in
Overall Diameter: 30.05 in 763.27 mm Overall Diameter: 31.64 in 803.65 mm
Sidewall Height: 7.02 in 178.30 mm Sidewall Height: 7.82 in 198.62 mm
Radius: 15.02 in 381.50 mm Radius: 15.82 in 401.82 mm
Circumference: 94.40 in 2397.7 mm Circumference: 99.39 in 2524.5 mm
Revs per Mile: 692.1 Revs per Mile: 657.3
Actual Speed: 60 mph 100 km/h Speedometer1: 56.9 mph 94.9 km/h
Speedo Diff: 5.294% too slow 5.03% too slow
Aditionally, the 3.73 gears will be reduced to 3.55 gears.
Thanks for the calculator link!
I've got the same truck and put on the same size tires. Have had no issues at all, and will in fact go bigger when I buy the next set. When I got the custom PCM, I had them correct for the bigger tires.
