Torque Management
A question regarding TM. (or should it be called torque impedance?)
I realize that TM affects the timing curve, and as a result the engine performance is restrained. I wish to know if the TM also affects the transmission and if so...what does it do and how does that work?
If I buy a tune (ie Westers) will it cure the transmission TM as well as the engine TM?
Thanks in advance
Thanks in advance
Short answer is yes.
Thanks, how does TM affect the transmission?
I believe one of the things it does is lower line pressure during a hard accelleration to lengthen the shift and soften the impact to the drivetrain. It may also change the timing of various components during the shift. I believe the majority of restriction is done in the engine via retarding timing giving you that "My truck just fell on it's face" feeling during that 1-2 shift.
I was AMAZED at the difference after my tune (with minimal TM) was installed.
