Coolant leak?
I seem to have a coolant leak in my 99 yukon. I might have 2 because there are 2 different wet spots under the truck when I park it. At first I thought it might be the water pump but I dont see any water coming out the weep hole. And The other might be the heater core but the coolant does not seem to be coming out the drain on the fire wall. the one wet spot is on the driver side bank in the front and the other is on the passenger rear bank. I'm thinking I could have bad head gaskets or warped heads is there anything I should look for when I tare into it this weekend?
Have you checked the coolant overflow botle? Sometimes the plastic welded seems along the bottom leak slowly. What about the radiator itself? Any greenish white powder deposits on the core? These would be the coolant leak spots.
The location of the drips may be misleading if you have skid plates under your engine. It's best to remove those then see if you can pinpoint the leak.
Also check your intake manifold gasket as that is another failure point.
Is it the 5.7 or 5.3 engine?
I have had very good luck with the gm product called "seal tabs". this was used in cadillac engines for many years and is harmless. most dealers stock it.
ken
That is an old body style Tahoe, so it is going to be a 5.7. In '99 they had problems with intake and head gaskets. While you've got the intake off to do the leaking intake gaskets, I'd go ahead and have the head gaskets replaced also.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
