poop on air intake good, now poop on tors
Found that there are 2 ways to life or level the frt of my burb. One is adjusting the t bars and the other is a new kit out there that gives you new torsion bar keys.
Ive heard some good and bad stories about both,
Will i ride and rattle?
Will my frt end fall out
is it really that easy to do ?
Scott
They are accomplishing the same thing, the keys will just give you more adjustment. Try adjusting the existing torsion bars by tightening the existing keys. You might need longer shocks to keep a smooth ride, and an alignment. (I didn't need the shocks, but I did get an alignment). If the height you get from cranking your existing torsion bars isn't enough then look into getting "Ford" keys, which are the same as those kits only for a fraction of the cost. Install those and you will get more adjustment. You will definately need longer shocks and an alignment if you do this.
