new here, my 05 gmc
05AZgmc
well here she is, 05 GMC Seirra ext cab, Work truck. Rubber floors crank windows, nothing special. i go in the dirt to much for carpet, and elec. windows just break after time, plus it was all much cheaper. only things i dont like are the center seat dosnt fold down to a console and no cruise control. I have some plans for it, but never owned a GM so i have no idea where to get stuff for it, hopefully you guys/gals can help me out with that. One one nice thing about my truck that i dont think many have is i got the alum block 5.3L. guy at the dealer said its somewhat rare. extra 15 hp so the books say. well let my know what you think. looking foward to getting exhaust and doing a little torsion key lift to it and some bigger tires real soon..
--David
Once you level her out and get some tires and wheels it will look great. :banghead: I have an 02 Silverado and installed dual exhausts and a 3"body lift. I still need to address the wheels and tires.
  • 3 weeks later...
Yes, new wheels and tires will transform the way it looks. Smart move paying only for what you needed, more money left for wheels and tires! You did spend money on one good area though, the engine! If anything ever happens to my 4.8, I know what engine I am going with....
Nice truck
:seeya:
Nice truck
:seeya:
Yea, those are sharp lookin'. Wheels, tires, and an SLE lookin' grille I think would be in order. IMO the flat colored W/T grills arnt' that appealing.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
