Something to Think About
Likarok
> Subject: Muslim Belief??
> > Allah or Jesus? by Rick Mathes..........
> > Last month I attended my annual training session that's
> > required for maintaining my state prison security clearance. During
> > the training session there was a presentation by three speakers
> > representing the Roman Catholic, Protestant and Muslim faiths, who
> > explained each of their beliefs.
> > I was particularly interested in what the Islamic Imam had to
> > say. The Imam gave a great presentation of the basics of Islam,
> > complete with a video.
> > After the presentations, time was provided for questions and
> > answers.
> > When it was my turn, I directed my question to the Imam and
> > asked, "Please, correct me if I'm wrong, but I understand that most!
> > Imams and clerics of Islam have declared a holy jihad [Holy war]
> > against the
> > infidels of the world. And, that by killing an infidel, which is a
> > command to all Muslims, they are assured of a place in heaven. If
> > that's the case, can you give me the definition of an infidel?"
> > There was no disagreement with my statements and without
> > hesitation, he replied, "Non-believers!"
> > I responded, "So, let me make sure I have this straight. All
> > followers of Allah have been commanded to kill everyone who is not
> > of your faith so they can go to Heaven. Is that correct?"
> > The expression on his face changed from one of authority and
> > command to that of a little boy who had just gotten caught with his
> > hand in the cookie jar.
> > He sheepishly replied, "Yes."
> > I then stated, "Well, sir, I have a real problem trying to imagine
> > Pope John Paul commanding all Catholics to kill those of your faith
> > or Dr.Stanley ordering Protestants to do the same in order to go to
> > Heaven!"
> > The Imam was speechless.
> > I continued, "I also have a problem with being your friend when
> > you and your brother clerics are telling your followers to kill me.
> > Let me ask you a question. Would you rather have your Allah who
> > tells you to kill me in order to go to Heaven or my Jesus who tells
> > me to love you because I am going to Heaven and He wants you to be
> > with me?"
> > You could have heard a pin drop as the Imam hung his head in
> > shame.
> > Needless to say, the organizers and/or promoters of the
> > 'Diversification' training seminar were not happy with Rick's way of
> > dealing with the Islamic Imam and exposing the truth about the
> > Muslim's beliefs.
> > I think everyone in the US and Canada, in fact the whole world.
> > should be required to read this, but with the liberal justice
> > system, liberal media, and the ACLU, there is no way this will be
> > widely publicized.
> > Please pass this on to all your e-mail contacts.
> > This is a true story and the author, Rick Mathes, is a
> > well-known leader in prison ministry
Guest chevydeerhunter
I don't care what Snopes says, it's gotta be true.
I just ordered a whole bunch of pills, refinanced my home and applied for a new student loan thanks to all the email I get.
    • Its coolant disguised as oil.   TSB - 20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
