time for coolant change
Hey everyone,
I've done plenty of research on changing the coolant in my 2000 silverado 5.3......and some recommend staying with the Dexcool and others say its fine to change it out to the regular 'Green' coolant.
Whats the deal with Dexcool??..........will the green stuff cause any damage?........most coolant now adays claim its perfectly safe for all these new engines.
I just want to make sure before I do so............any advice would be appreciated...... :D
I say dump it, I've heard from many mechanics who are not pleased with the stuff, it has caused problems in the cooling system. I trust the mechanics who told me this.
Do as you wish. I have seen S&T trucks with extreme coolant clogging with dexcool but that was caused by material left in the block at the factory. Just flushed a 2000 today with 111,238 that looked great, but what do I know. Its not like I do this for a living. Wait a minute, I do. :D
What do they use in the '06 trucks? The same Dexcool coolant or some new formulation?
Use Dexcool! Why is everyone so affraid of Dexcool? I've never had a problem with it in any of my vehicles or any of my family's vehicles that use it (that's 5 GM vehicles so far with many many miles).
Ryan............did you get rid of your Dexcool and replace with the 'regular' coolant??.......if you did..........has everything been fine with your truck?.... :D
Well here's my take on it. Use what ever you want. I prefer the green so I don't get complacent and leave it in longer cause it's "long life". In all my research and of course I work on em for a living, I have come to this realization. Use which ever let's you sleep at night. neither will damage your engine (although the red stuff likes to gel up it subjected to air in the system) I have also come to the conclusion that it's ok to mix them. Why you ask would I mix them since it say's they don't mix. Well It's true if you mix a 5year antifreeze formula with a 2 yr formula you no longer have the 5 yr or 2 yr warrenty, cause you diluted the 5 yr and added to the properties of the 2 yr. Hence the aftermarket came up with add to any make or model stuff. If ya add it to green it's good for 2 yrs. If ya add it to red it's good for 5 yrs. NEITHER WILL DAMAGE YOU ENGINE. of course this is an opinion. I have green in my 96 monte and the factory stuff in the 03 silverado. I will probably go with the any make or model stuff when I change out the truck so I can add either if I'm stuck out on the road and they ain't got what I want but I prefer the green cause it doesn't sludge up as easy as the red.
Thanks for the reply.................thats what I wanted to hear...........im going to change it out to the green stuff..............its just more readily availble when needed and my other vehicles use the green coolant as well....... :D
Dex, sludge up huh? Wow I should have had this happen by now according to your post. I guess that since I don't neglect my vehicle it doesn't do that. Where as if you have the green you can just blow it off and this will just be fine. Not bashing just pointing out the reason for green, to be lazy and blow off normal maintenance.
Have a great day.
Have a great day.
Do you even read a post before you start bashing?
Have a great day.
Have you?
I wonder if maybe the formulation has changed?
I had 96 and 97 Blazers and both had alot of coolant issues to the point of constant flushes, multiple heater cores replaced, 3 radiators and they even put new overflow tanks in. But they also had the intake issue so maybe that was a factor as well. All I know is that "long life"coolant never had more than about 15k miles on it at any given time since the dealer was always flushing and replacing parts and it was always black and sludgelike.
The stuff in my truck appears to be holding up better, already at 13k and no issues. I really haven't heard too many complaints here about the new dexcool.
I now run the Green stuff, but the damage has been done by the DexCool, there are coolant leaks all over the place starting to pop up. The Mechanics at the repair facility I use as well as others state that the stuff can turn acidic and eats away at the various seals which is what has happend in my case. They say if you are going to run Dex Cool do NOT do a 100,000 mile service on it, but rather every 3 years or 30,000 miles, 50,000 MAX. I believe them.
    • Getting greedy...   The AC pump has been replaced at least once per service records, and it's been recharged twice since 2018 or so, in approximately 2 year intervals between those charges.   It was done at the same shop...clearly they were enjoying the revenue of recharging the system periodically versus actually tracking down and fixing the leak. I learned that the owner was 88 years old when she passed in 2023, so maybe they assumed only a temporary fix was needed anyway.   The system is basically empty now, the compressor spins freely, so I'm guessing it "just needs a recharge".   I vacuumed it down, and it has basically held overnight. Doesn't appear to leak under vacuum, check! So it must leak under pressure. I don't have a way to pressurize the system and pressurizing it with shop air wouldn't be great for the air dryer (which is probably toast anyway?)   The dryer (accumulator? I'm not an AC expert) has a Schrader valve, but the high side has an old ball-type valve, which are notorious for leaking. It's clearly had schmutz blown out of it at one point because the line/area next to the valve is coated old black crud, which I assume is AC refrigerant residue/oil, or maybe even dirty dye. I think I'll roll the dice and replace the valves. I have a black light around here somewhere so I'll find it and shine it around the engine bay in the dark to see if there's any dye.   I can't think of another way to track down the leak other than injecting some dye (if it doesn't have any) and having it charged up. We can't buy R134a off the shelf here anymore, so I'll run it up to Jiffy Lube and have them do it. I think I have a coupon. At the very least, the charge should last long enough for a year or two, according to history. I think this truck will be long gone by then. But cold AC is a selling point.
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
    • If I forget the phone in the truck, and forget the truck in the phone, and reconnect.  It works great for the day.  Truck sits overnight, and the next day is a no go.  It will connect Android Auto via usb cable, but not bluetooth.   Ive tried Everything in this thread so far, and nothing works for more than a day.   I think I might have to go to the dealer and have them flash the pcm.   thanks for all the suggestions guys. 👍
    • 2022 2500HD Crew Z71 Duramax single alternator.  Recently had the primary (water pump / fan) belt tensioner pulley bearing to fail while hundreds of miles from home of course the plastic pulley melted and belt shredded which took out some wiring. Found a replacement tensioner assembly and belt to continue now would like to find a replacement for just the pulley and bearing to have a spare assembly in case of a repeat, the rest of the tensioner is fine. Has anybody here found a correct replacement part for just the pulley and bearing? Any help is appreciated.
    • +1 for the 3.0   Perfect for 1500 pickup towing duties.   Perfect engine for a 1500 pickup period. Huge torque at stunningly low RPM makes it feel a lot lighter than it is. The fuel mileage is insane for a tall and heavy 1500... 30+ on the highway. Mid 20's around town.   It's probably not perfect if you bought a 6.2 for the braaaaaaapppppp V8 noises and wrapping it out to 6k. The LZ0 acts and sounds like a small turbo diesel and there's nothing you can do to make a small turbo diesel sound like a big one, and you can't make an inline diesel sound like a V8 diesel/big Duramax. It's a different driving experience altogether.   Drive one, I think you'll like it, though...
