power steering trouble
i have a 2000 z71 and i have a strange problem. i cannot turn my truck to the right very easily. it turns fine to the left but feels like the power steering is not working when i turn right. i tried to fix the problem by changing to a new power steering pump. after i did that i had the same problem. new pump...still no power steering help when i turn right.
any suggestions?
thanks.
any suggestions?
thanks.
It is in the box. It is not the pump because if it was it would effect the turning in both directions. The is a spool valve that is in there thcontrols the boost that is likely bad or you may have a bas seal on the boost piston, eitherway it is time to replace the steering box.
