New Here
04Prox2
I just wanted to say hi to everybody here. My name is Mike and I just recently bought an 03 Chevy Silverado Z71 Ext. Cab in Arrival Blue. I'm from southern NH and am going to be a senior at Plymouth State University in the fall so this truck has been a dream for awhile. The truck has been a HUGE improvement over my wimpy tacoma I had previously and it tows my snowmobile alot better! :)
Guest chevydeerhunter
Thanks guys. Sorry for posting this in the wrong spot I just noticed the newbie area.
Well you're a newb and you screwed the pooch already! :happysad:
Welcome to the forum and congrats on buying a REAL truck! :happysad:
Well you're a newb and you screwed the pooch already! :cheers:
Welcome to the forum and congrats on buying a REAL truck! :P
Haha yeah I did. This is a MAJOR improvement over that pile of junk TRD. I had to go back to the dealer 10 times within 36,000 miles with that thing.
You must know something. On this forum, if there aren't any pics, your ride doesn't exist.
How do I post them? I don't have many of the new truck but I have a few.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
