remote turn on "type of wire to use"
on-going trying to get my amp to work, im thinking its my remote turn on wire that is bad.... so today i went to circuit city, and radioshack, and both places did not have any specific remote lead for sale other than in a kit (which is the way i originally bought it)... so i asked the installers there what to use and they said just to take a speaker wire, splice it down to one wire / lead, and use that... i questioned him about the current going threw it, and he said its a very low amount that the speaker wire will be more than safe to use! so i went to radio shack and the guy there also said speaker wire... now before i hook it up and risk it , is this recommended? ok to use? thanx in advance
that is what i use also. i usually just use both wires and tie them together on both ends and i also add an in-line fuse just in case something goes crazy.
Remote wire can be very small 18 gauge. The remote signal will be less than 1 amp.
If you're in my area I'll give you some for free.
thanx for the replys..... im gonna try it out tommorow. hopefully im rightg about my old wire being shot.... if this dosent work, i give up! lol
mrinstall- im in buffalo ny.. but thanx for the offer
Alot of newer aftermarket decks now have 2 blue wires in the harness, one for remote turn on and one for a type of display dimmer. If this is the case you may just be hooking to the wrong blue line.
great news! i got it it to work... actually i cant take the credit for it.... those familiar with buffalo ny, Darryl's car audio "hooked me me up" i went there as a last attempt to get this working after trying for WEEKS! it turned out that my inline fuse was fried, and the remote turn on wire was bad... so after just quickly hooking it u ghetto style with wires drapped over seats and dash, i went home and re-routed everything so it looks factory!
Oh yea- btw- about darryls car audio... "kudos" to them for the excellent service! when i asked them how much i owe him... i was expecting at least 30-40 bux... he said dont worry bout it! i was like WOW! So thats why i say he hooked me up! free remote turn on wire , about 15 feet, and a free fuse! I now will do all my audio business thru them! thankyou everyone here for your help tho!
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
