Tree fell on my house last night.
Ouch....not much damage I hope.
More importantly, no one got hurt?
no damage except my light over the door. funny thing was when I woke up and heard it I thought it was my gas can bandit back and I went running out the door in my boxers and spotlite ready to kick some hippy a**. :D
That sucks. We get plenty of downed trees at work due to it being an older community. Thankfully(or not) there are no trees around my place as it used to be farmland.
We had a Tornado go through just 2 miles north of were I live last night. Tons of tree's down. I'm heading out at 10 to go stock up on firewood.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
