98 c/k1500 engine reccomendations
I am new here and I have a question, I have a 305 5.0 inside my 98 chevy c/k1500 third door ext. cab. I want to know how to make my engine better, I want it better looking, better running, better gas mileage, and longer life in general that is MY MAIN CONCERN my SECONDARY less important concern is to get more horses although I wouldnt mind them, a supercharger isnt at the top of my list. I mean I just need advice as to how to make it better engine in general, like even good enough to be able to "show-off" :banghead:
K&N intakes make a world of difference and looks good too. A good quality cat-back systems will add performance and looks. What looks cooler then big chrome pipes out the back.
You could try getting a performance tuning, there are a whole lot of threads on those, on here.
Now for a little more in depth...you could always go with a mild cam, but unless you can do it yourself it is not very cost effective. The same goes for a transmission shift kit. Both are in summit but require a bit of mechanic ability.
As far as long engine life, just keep up with maintance and don't over do it on the showing off. The 305 is a great little V8 and there are limitless possibilities on modding it.
Get some performance magizines like "Jegs" or "Summit" they carry tons of small block GM performance parts.
hey if someone has time could you go to jegs.com and copy and paste this into the parts number, its what im thinking of getting but I dont know if its good. 289-19303
# Cat-Back Bolt-On Exhaust SystemDual Tail Pipe
GM
# C/K 1500 1998-99
# C/K 2500 1998-99
# 4.3L & 5.0L Engines
# Ext. Cab Short Bed
its from dynomax
